colhel
I've looked at the Hunter and Jeanneau range. Are there any others? Does anyone have this type of layout on this size of boat? I'd appreciate any comments please
Open plan layouts are an invitation to disaster; a seagoing boat should have limited distances to get thrown around, coupled with handholds.
I found this to be true when test sailing a Hunter Horizon 27.
Have a look at the Kelt 850. It's not quite open plan but has a v attractive wrap around saloon. If you put a search into Youtube there's a video of the interior of one.
You really do need to get away from your outdated ideas of what is good and what is bad - or rather the idea that only you know what is good. It is clear that many people value open plan layouts in small boats and back their judgement by buying them. As a consequence builders make them. The OP clearly sees benefit for him so is looking for one - so who are you to say that he is wrong?
I believe the issue is where there is an area thought 'Open Plan', there will be fewer handholds to combat significant pitching and rolling, than if there are more partitions, or closed area that folks can grab or steady themselves against.What has open plan in small boats got to do with getting thrown about?
Whether there is a full main bulkhead or not makes zero difference, as most movement internally is fore and aft and dependent on sensibly positioned grab rails or handholds.
Why do folk feel it necessary to contribute negative red herrings to every debate?
Asking too many questions here perhaps?
I've been in open plan boats and traditional layout ones, 20' upwards, in waves; the open plan jobs were definitely more troublesome as soon as things got lumpy, and one tends to get thrown athwartships a lot more than lengthways, though both are a pain.
Try it !
Tranona,
it is you who need to stop homing in and disagreeing with anything I post !
While the attention is flattering, it remains a matter of common sense let alone seamanship that an open plan layout tends to leave crew large spaces to be thrown about in unless there are plentiful handholds, and I've yet to to a serious blue water boat boasting an open plan.
Now let me guess what sort of interior your boat has...![]()
Well, I would suggest that the open plan Pacific Seacraft 31 is a pretty good example of a blue water yacht.
