Yacht beached and freed
Personally, I would have wanted a spreader rig on the crane. Lifting something the way they did puts undue stress on the lower side where the deck meets the hull. Something like the one below perhaps.
Also, what is it with this awful music everyone seems think goes with videos?
Yes,horrible music,had to turn the sound off.
Recon he was just glad to get off the beach
Interesting
Do you think it was damaged ?
There must be some damage if only abrasion of the surface coating, but it doesn't look terminal. So much depends of the strength of the structure & the amount of pounding (duration & weight) & the nature of the beach. Sand is hard, very hard, but it forms to the shape of the hull & that spreads the loads. Pointy lumps of rock in the sand will punch holes thro the hull & can damage formers catastrophically, but I don't see anything like that there.
It's surprising how Concrete, GRP, wood & steel can take the punishment & still be repairable. Carries a lot of cost, pain & heartache tho.
It was in Bali, and I think they did well to get a crane and excavator. Did anyone else notice that the yacht's boom was missing?
EDIT: They were lucky to be ashore on sand, there was a rocky looking headland quite close.
Speaking of grounding I saw a boat today just off North Connel below the Falls of Laura(Loch Etive) in full spate which didnt appear to be in the right place and no obvious mooring bouy!
I suspect it might have been blown across the chanel from the moorings off South Connel!
Boat in OP's video looks like a Standfast 40, a Dutch-built design from the 70s. If so, the hull is about 1.25" thick (foam core sandwich).
Any further info? NOT anice place to be, even if IN control of the situation.
