Would you fill a hole below water line with this?
VicS
13 Jul 2002
No . It only contains a relatively small amount of glass fibres
You dont say how big the hole is but the West System website has all the necessary info, how to guides and a video to guide you through the procedures for "repairing" a hole of any significant size.
http://www.westsystem.com/
An epoxy filler or putty would probably be adequate for a small (screw) hole
easton
21 Jun 2013
A 2" diameter hole ought to be tapered out to probably a 12" diameter hole, and filled with progressively larger fibreglass circles until it's the same thickness as the original hull, squegeeing out excess resin, then finished on the outside with gelcoat, faired as appropriate and antifouled.
At least that's roughly what I would (pay someone else to) do...
The effects could be pretty spectacular (or deadly) as the disc of P40 pops out and the boat develops an indoor fountain, then swimming pool and then distinctive lean...
VicS
13 Jul 2002
Filling hole from 2" through hull.
Repairing a 2" hole is a major job .
As suggested it involves chamfering the edges at 12:1 which produces quite a large area to then fill with layers of glass cloth and resin.
However not by starting with the smallest piece, as easton suggests, followed by increasingly larger pieces but by starting with the largest piece, equal to the size of the whole chamfered area, followed by pieces of progressively decreasing size so that the last piece is the size of the original hole.
sailorman
21 May 2003
Here or thertemp ashore
NO wrong. Read the guide on the West System website
Yes right, from a fellow who professionally mended FG boats to an exceptionally high standard. You are reading theory, he did it before Gougeon Bros wrote their book.
Just think about it, not read about it. The last laminate encapsulate all others
VicS
13 Jul 2002
I don't get it, how can you fill/glass largest first then get to the smaller areas ?
The first piece covers the whole of the prepared area, like laying it in a saucer (with a hole in the middle). Each subsequent piece is smaller until you have nearly filled the saucer level. The final piece being the size of the original hole
You stop just short of filling the saucer level in fact to allow for shaping a fairing
By bonding the patch into place in a large-to-small-piece sequence, you will eliminate the possibility of sanding through any of the cloth layers when fairing the surface.
Read the West guide on Fibreglass boat repair and maintenance.
Tranona
10 Nov 2007
