wee_niall
wow, that does sound cheap! not sure when i'll next be through in weegie land though (last time i was there was last april going through the Forth & Clyde!) but i'll bear that in mind.
Not a bad idea but I’m quite keen to keep things fairly standard and not get into having to get custom things made up. There’s also the problem that the worn bit hasn’t worn even so would need more than polishing and the rest of shaft aft of the bearing would need reduced. I’ve asked the engineers for a quote to reduce the diameter of the last foot so hopefully it will be nice and cheap
Dont get it turned down and sprayed, as it does fail. we had it in the 70s.
Lastly does the coupling have the same taper, so you can turn the shaft?
If not have new shaft made with equal tapers each end along with a new coupling, then you will get a double life from each shaft, in the future
Last thought is there room to have another coupling fitted between the existing one and stern tube, then you can get the intermediate bit made in steel, and the length to do the double taper on the existing shaft, along with it being shorter for replacement in the future.
Mine w as made in Buckie or Banff by a fishing boat engineering company whos name I can't remember, cost about £80.
Know what you mean by keeping it standard BUT! If you buy a standard 7/8" bearing its OD will be 1 3/8" but the 1" bearing fitted at present will be 1 1/2" so you will need to get a nonstandard made up, hence suggesting a composite bearing rather than a rubber one.
These are the dimensions from Norris, other may differ.
I can only think the prop and shaft assembly is out of balance to cause uneven wear like this. Is the shaft straight? If not the machine shop should be able to straighten it for you. Even new shafts are often not straight especially after machining.
It's uneven lengthways rather than being oval or anything like that (if that makes sense?) - i think it's just the way the cutless bearing has worn meaning that the wear is slightly more at the very aft end of the bearing.
my cunning plan has hit a snag - it looks like the cutless bearing is actually a stuart all rubber type so getting an undersized replacement is going to be even more difficult that i thought! Along with spilling a 750ml can of danboline in the engine compartment it's not been a good day
it does look like the 5th option might be the best - although the other (still expensive) option is to replace the bearing housing but that seems like even more work! I'm going to scout out Neil_Y to see how much a custom composite bearing would be (just need to get the dimensions).
Out of interest, how are the stuart bearings held in the housing? Are they just squashed in? The old one is impressively smooth and looks to be as old as the boat
