ghostlymoron
Keep going swanrad success is within your grasp.
If anyone is still reading, I will pass on the engineers comments today. Should of been fairly obvious really, but in my keenness to get to combustion I didn't do it. The next stage suggested by him, empty the fuel tank - while we are at it either refurb the tank or replace it, change the tap on the old one as they are useless. Replace all the filters, give the engine another service. Try again-it must be the fuel, if we do this and it doesn't work then call him again. There is, at that point, a reason to involve his skills - for now, I think he was politely suggesting what we need to do can be done by us far more cheaply.
He did tweet the stop button (seemed to move) and the throttle, seemed OK.
Good man - lives and works in Beaumaris.
Bit mysterious!!!! Are you saying that there was more water than fuel in the diesel tank!!!! Does make things difficult .
Sounds like real progress. One thing, though, do not connect the new water inlet valve to an anode. Not necessary as there is no connection between the valve and any other metal.
Interesting - it was connected before, albeit with defective wire. I assumed it was because the gunmetal strainer was a different metal to the valve. Was I wrong?
I Agree with Tranona regarding the inlet valve and anode. The skin fitting valve and strainer should all be corrosion restant and not need an anode. It was once fashionable not connect everything to the anodes , but it is now recommended that it is not done
Connection of the seacocks to the anodes was one of the factors blamed, by the MAIB, for the near loss of the F.V, Random Harvest a few years ago.
A problem I met up with on a Westerly was that the basket in the strainer was brass and dezincified .... An anode would not have prevented that.
Great - saves me a job and its not often that happens!
This does raise another worry though in that if the strainer and valve are corroded - does this say anything about the skin fitting? It looks OK...
One thing well worth checking is the core plugs; I had one of these on a Volvo fail on me and develop a leak, naturally at the top of the Alderney Race in a flat calm; Araldite saved the day but we had an uncomfortable half hour spinning down the race while it set.
I now always carry Araldite Rapid on all boats...
I have some of that modelling epoxy putty (can't remember the name - getting old, begins with an M) for just such a job. Don't know of it will work though....
Milliput.
Sounds like the water intake hose, between the seacock and the water pump. This hose has a propensity to delaminate) & when the revs rise, the inner wall of the hose closes in on itself, blocking water flow.
For the priced of a short length of new hose, it's well worth a quick replacement that may very well solve the overheat problem.
