ghostlymoron
don't go there.-thinking of joining the outboard well in a Centaur debate -![]()
A quick update for those who are interested.
Cost so far a staggering £752 including service items, spare impeller and Belzone 1111, which may not be necessary. Excluding these frivolous items the head rebuild is up to £601.54.... and we don't even know if the thing will start yet...
Happy days.
Still a long way to catch up with the money I spent on my Ford 1.6 D
Recon Cylinder Head £350 (Later found to be cracked)
2nd Recon Cylinder Head £450
Rebore, new pistons, new main bearings, new big end bearings, balance of crankshaft - flywheel - flywheel mass - drive plate, water pump, gaskets, special TTY bolts ~£800
Refurbish Injectors £100
Refurbish Injection Pump £300
~£2,000 total with all of the strip down and rebuild work done by yours truly.
Never - never - never again but don’t let be discourage you
I took my Ford Consul engine to bits when i was skint about 45 yrs ago, you learn a lot, EVENTUALLY,I think this is one of those lessons you have to learn for yourself, it's a bit like smoking, just one more wont hurt - it gets you inch by inch and one by one! I think you cant overestimate the value of
1) taking an engine apart to learn how it works and to remove the fear
2) not having to take the whole lot out and replace it - as much as you buy an engine that used the same hardware in the boat, I still think other things would need to be bought.
On balance, so far, I am glad I did it - I will NEVER neglect those little details in engine maintenance again and I am no longer scared of diesels. Now that is liberating - if very difficult to explain to those who understand engines.
The water circulation wasn't great anyway, I had the exhaust elbow off to help - it did. We had to run the engine for 5 minutes with very little or no water circulating and overheated it for the sake of safety, replacing the impeller soon after. After this event the amount of water decreased and when at temperature and higher than 3000 revs this turned to steam - I thought head gasket most likely under those circumstances.
The process I am contemplating is therefore take the head off and clean up where possible and replace the gaskets (mechanic friend willing to work for beer makes this doable). The boat has been sitting for nearly four years now so a coupe of bits need freeing off and cleaning up, do this. Service the engine. Start it and run acidic central heating solution through it for a few hours.
I am the definition of 'not an expert' but this seemed like a sensible order to work in?
Don't let Dylan wind you up - you're doing the right thing!post it here
I love inboard engine threads
If it is the head gasket the sump oil will be milky where the water has mixed with it? Just check the dipstick
It's surprising how few threads there are about re-furbishing inboard diesels considering how many engines there are.post it here
Thanks for the update, I have been following your thread with interest as my engine is waiting to be done. Hope your professional gets you sorted out!
We have waved a little white flag at this point and are preparing to call in the specialist as fiddling with injector pumps can end badly I believe (heard two stories of engines revving themselves to death with stuck governers after badly aligned injector pump replacement). s!!!!!!!
IF you removed the fuel pump then take it off again and check the fork on the governor lever is fitted around the wee brass ball on the pump rack pin. If sitting to one side the engine might go to full speed and run away and if fitted to the other side it could be shut off and no way of resetting the rack. Simpleessss
You did replace the brass ball????????????????
