Babylon
Meh. Could just be that baby girls socialise faster and so respond to human shapes earlier. Psychologists can't do experimental design for toffee.
Duck, lame.
Of course there has to be a skipper for legal reasons,
But she has limitations. Among them are an absence of brute strength.
The only one that might tax my strength, I think, would be if the manual anchor windlass wouldn't work. (Currently I handle a 35lb anchor on 12mm chain which is stowed on deck, not the bow roller) Even then, I believe I would manage it, albeit slowly, with help from the engine. As mentioned above, I think what's important is technique, the ability to use the right equipment and the belief that you can do it.
1. In what world does one attach a 35lb (16kg) anchor to a 12mm chain weighing in at a whopping 4kg per metre![]()
2. Would manhandling a 12mm chain + anchor dangling on the end not be best best left to those East European/Nordic types ..........blokes or wimmin?
I have always have trouble getting my head around this point. As a slightly built woman well on the wrong side of 60, I have yet to encounter any real need for brute strength in a long sailing career. I have owned (and raced) many dinghies, a keelboat, a wooden gaffer, of which I was sole owner and a heavy cruising boat, of which I am also sole owner. I have also sailed in many other boats, in size, 70 foot down to my 8 foot lugsail dinghy. I have been "skippering" my own boats regularly since my teens. My crews often consist of groups of women friends, mostly with very little experience. I have also earned my living as an instructor and by working on big yachts sailing all over Europe and the Baltic.
Brute strength was needed to hoist big gaff mainsails on the big gaffers that had no winches, but only if we had limited crew. Otherwise I am hard put to it to remember any situation when my brute strength has been essential. The only one that might tax my strength, I think, would be if the manual anchor windlass wouldn't work. (Currently I handle a 35lb anchor on 12mm chain which is stowed on deck, not the bow roller) Even then, I believe I would manage it, albeit slowly, with help from the engine. As mentioned above, I think what's important is technique, the ability to use the right equipment and the belief that you can do it.
"Problems of perception rooted in femininity" is a red herring and part of the stereotyping issue that has been discussed. Whatever intrinsic differences there may be between men and women, they are all on a spectrum and the spectrums have huge overlaps. And in any case either may confer advantages as well as disadvantages in sailing. I'm afraid what is true of any particular "SWMBO" is by no means necessarily true of other women and might turn out not to be true of SWMBO if she was sailing in some other setting. I've seen that difference often, when SWMBOs come sailing with an all woman crew. You might be surprised.![]()
They are lifting and stowing heavy gear, such as sails. Rowing against the tide. Hard winching in a blow. Handling gas bottles.
I have dealt with the anchor for a long time, partly because my husband developed some back problems, but also because I know that if there is anything in the routine management of the boat that I can't do, I shall have to import some Eastern/Nordic hunk to do it for me. Sounds OK, but where am I to find one?(In any case, I'm a very independent minded cuss)
ps: If you do start a new thread you might want to confine it to precise engineering questions as anchor threads on here can end up like basra on a bad day!
I don't want to drift your thread here, but do start another one if you'd like some serious advice on anchors and chain. You might be surprised, but something like a 15kg Spade and Grade-70 8mm chain will be lighter, more reliable, more roll stable and near as dammit as strong as your 12mm chain. It will also be stronger than your proposed Grade-30/40 10mm chain, which I 'suspect' may be somewhat OTT in any event.
As far as chain is concerned, my main concern is replacing the windlass as well as the gear. I have, however, reduced the weight by replacing half of it with nylon. Also, there was a great lump of lead ballast up forward that came already installed when the hull arrived and that has been removed, so some balance has been restored.
Sounds like you're well on the way! Just one more thing: as I'm sure you know you will almost certainly only need a new gypsy to covert to a different chain and they often come up on the For Sale Section.
Right time to join Babylon under that rock![]()
I solved the heavy lifting thing for my wife
I bought her an electric golf trolley. Seems to have solved the problem.
We no longer argue- we cannot as we do not see each other that much really
Seems to work quite well as her handicap has come down & i get to go sailing a lot more
That's useful, thanks again. It's a very old SL vertical windlass (with warping drum, which is sometimes very useful) so I'm not sure if spare parts would be easy to get hold of. There was a bloke in Glasgow who knew all about them, but he may be deid and gane by now for all I know.
I hope you are not under the rock on my account. I'm a pussycat!![]()
Serin,
A lot of the SL windlass parts were interchangeable, and in our garage is an old electric horizontal S/L with an 8mm drum+ a certain amount of prehistoric but regalvanised 8mm chain.
My Pilot/Electromechanian/ERA/Sparker/Buoy jumper may well give her permission for you to see if it fits!
I am the Master under God of our Boat, and I have my Wife's permission to say so, esp. if all it goes pear shaped![]()
As far as I know, this chap John is the only fella that has new spares for these windlasses...I sent my 40 yr old SL windlass to him 2 yrs ago & he did a very thorough internal refurbishment on it.
SIMPSON LAWRENCE Windlass Spares
5 Crestlea Avenue, Paisley,
Renfrewshire.
Scotland.
PA.2-8.BG
0141-589-6287.
