Wiring up a shunt
VicS
13 Jul 2002
Ah, so when these electrons get "tired and shagged-out by passing through a load", as Nigel so clearly put it, they crawl into a hole for a rest, do they?
I dont know if they really get tired and shagged out but they go into their holes when you turn the switch off.
boatmike
30 Jun 2002
Solent
Gawd fellers, I have just got home and decided to just check if anything else had been added..... Talk about Fred Drift... Its SUNDAY!!! Don't you guys ever go out??
VicS
13 Jul 2002
We keep the thread alive and near the top of the first page and that all the thanks we get! ;)
William_H
28 Jul 2003
West Australia
Electrons and holes
Hi Vic
Continuing the thread drift madness......No they don't all go into their holes when the switch is turned off. The electrons left in excess and holes left wanting is called capacitance.
Consider that if you had a circuit of a battery a switch and a lamp connected by wire to operate correctly. Now consider that the wire has been cut. When the switch is closed do the electrons have to shuffle down the wire and pull down the wire on the other side only to find there is a gap in the wiring? The answer is yes. The electrons will pile up on one side and the holes will appear on the other side until the electrons and holes are finally convinced that current is not going to flow. The size of the pile up depends on the proximity of the 2 wire ends, the area of the ends in proximity and what material is between the ends. So if we take this to extremes of square meters of ends just microns apart we have a capacitor. Amps can flow in, slowly diminishing until the voltage across the gap rises and no more current flows. If we disconnect the battery and lamp we find that this tension across the gap of excess electrons and holes remains until a circuit can be made to allow them to get back to normal relaxed. If we reverse the battery and connect again then a large current will flow to dissipate this tension then rebuild it in the other direction. Indeed this capacitor can look like a battery albeit of small capacity and a voltage which falls rapidly. Capacitors using this effect are an essential building block of any electronics.
Hows that for being pedantic and for thread drift. olewill
cimo
11 Nov 2009
Its funny the things that stay with you.
One of my first engineering texts put it very well with a quote from Aristotle -
"it's the mark of an instructed mind to rest satisfied with that degree of precision which a subject allows, and not to seek exactness where only an approximation of the truth is possible".
I'm paraphrasing, but he was right then and he's still right today.
Very Zen I thought.
It is/was indeed Sunday, and I have been out all evening & it is possible to get graduated analog ammeters.
I'd be very disappointed if I were to have the last word on this matter.
boatmike
30 Jun 2002
Solent
That's approximately right.........
