Bobc
Personally, I don't see the point of them. I want to be stood on the foredeck watching it all come in, so if there is a problem, I know about it immediately.
I said I liked it - what more can I say. Don't you like praise?Your point ?
That sums it up - the magic word is "survive". If they did not exist you would find ways of working without. But they do exist so any sensible person would look at them and decide whether they add any value. Clearly they do as plenty of folk use them. In reality handling anchors is often not easy so the process may start from basics - how can I make this better and remove real or potential problems? I got my first remote the latter way after the hard wired cable that ran across the line of chain got caught up and ripped out (bad design and carelessness in not compensating for it). Wireless remote an elegant low cost solution.I tried to indicate there is an alternative to a remote - they are not essential, people (or at least me and Bobc) survive without them. In this thread I have described how we have managed for 25 years without a remote.
Jonathan
I really find it difficult the envisage where else on the boat you would want a windlass controller, so if you have both helm and windlass locations having a remote seems - redundant.
Jonathan
I've got this one on my windlass. There is a delay but it isn't much. I was going to get another foor the BT but they operate on the same frequency / code so not much good unless I fit 30 feet of wiring etc to be able to disable the windlass solenoid.The cheaper wireless 4WD winch controlers are great value for money. See below:
For around £10- £15 these are a bargain. They are a great adjunct to a wired remote or foot switches. The freedom to operate the windlass from anywhere on the boat is very beneficial.
Given the very low cost of these units (and easy installation) every boat that anchors frequently (and has an electric anchor winch) should consider purchasing a wireless anchor remote in my view. Additional alternative back ups for activating the anchor winch are also sensible.
However, these inexpensive wireless units do have limitations such as the longer delay that the OP has noted.
For slightly more money the industrial wireless options that I have posted above are an alternative solution. These units fix most of the limitations of the very inexpensive units for not much extra cost ( in boat money).
We use our wireless windlass remote almost exclusively (although we have wired back ups) so the performance is important. The industrial wireless remote units have been our best solution.
You didn't learn anything, apart from how to selectively quote, to distort what was said, to suit yourself.I said I liked it - what more can I say. Don't you like praise?
I learnt: You have a large Motor Boat, you have crew that can take the upper, helm, other crew who can manage the windlass and you can stand at the bow keeping your eye on things. No mention of remotes. Why would you need one if you have one crew member at the helm and another at the windlass - provided they communicate you are not actually needed. Certainly no mention of using a remote nor why you need one.
I don't know why you bother. The poster in question is for ever derailing threads, telling others they should do things only the way he does them, and telling you how you should post on the forum.You didn't learn anything, apart from how to selectively quote, to distort what was said, to suit yourself.
What i said was;
"I have also fitted a wireless remote, i can stand at the bow while crew take the helm and operate the windlass whilst keeping an eye on things. I'm not restricted to any particular spot on the deck, such has having to stand on foot switches and can easily lean over to remove weed etc from the chain whilst using the remote."
So much for "no mention of remotes"
It's also clear that the only crew interaction is the person at the helm, i'm using the remote at the bow to retrieve the anchor whilst keeping an eye on things.
Never had any problems with my quick controller in over 20 years.Even if you are standing at the bow when you are winding in the anchor the remote has the big advantage of no control wires/switches/socket etc have to be run to and maintained at the bow. So much less to go wrong (and yes they do go wrong in that environment).
My only issue is that when I take my finger off the button it takes a second to stop. This is getting on for a foot of chain..This makes fine adjustments very difficult..
Is that wireless? If not then does not help as the OP is asking about wireless remotes.Never had any problems with my quick controller in over 20 years.
My comment was in response to a claim that wired ones are problematic.Is that wireless? If not then does not help as the OP is asking about wireless remotes.
Don't recall anybody saying the device itself was problematic - they are generally reliable if kept dry, rather that in some cases it is not convenient and for some uses a wireless remote has quantifiable benefits to the user. The downside identified by the OP is that cheap ones have a delay in stopping and starting, but better ones don't.My comment was in response to a claim that wired ones are problematic.
The first one I had 20 years or so ago was not a cheapo and had no delay but can't remember the make. It was then about £150 or so. The last 2 have both been Sidepower dual function and work well, but are close to £500. The Lewmar windlass only are about half thatSo does anyone know of a slightly more expensive one with no delay?
Units similar to mine are quite readily available on Amazon, eBay etc. Another alternative is Chinese websites such as Alibaba, as the units are reasonably expensive in the UK. I paid about €50 for mine six years ago. Search for "industrial crane winch controls".So does anyone know of a slightly more expensive one with no delay?
