Wireless remote for windlass
Nice. Some of that kit looks more robust than mine. We will see how long it lasts. Fitting a hard wired momentary rocker switch as backup.
I'm interested in the remote auto pilot thing. The raymarine android app is junk. Frustrating as it's rletivrly low tech and all I want is to remotely do the plus and mi us thing. I can't see an easy mod to the current setup though.
Spyro did it in his Raymarine http://www.ybw.com/forums/showthrea...Tiller-Pilot&p=6629555&highlight=#post6629555
And I did it to my Simrad http://www.ybw.com/forums/showthrea...s-remote-to-Simrad-tillerpilot&highlight=tp32
As I understand it the Simrad wheelpilots use the same pcbs as the tillerpilots, so the electrical work will be identical although finding somewhere to mount the wireless receiver will be a different challenge.
but unfortunately the forum software has removed the pictures. I'm not going to waste time putting them on here again, but if anyone's interested I'll put the whole 'how to' somewhere else and provide a link.
Excellent....
Mine is a wheel pilot with the controll on the dash and all wired to some sort of computer box where the rudder sensor compass power all converge... But looking at the various posts it may be that it is just a matter of tapping into the buttons. With the remote fitted in behind the dash...
That brings the next question ...can the remotes be paired to two different boards... This would allow one board to be connected to the windlass directly with a second board fitted behind the autopilot...
Excellent....
Yes, electrically it's that easy (needs 12v supply too). It's paring down the 'receiver' end to fit the tillerpilot that took the time.
According to the Chinglish instructions for the one I bought (https://www.ebay.co.uk/itm/12V-4CH-...83.l10137.c10&nordt=true&rt=nc&orig_cvip=true) the implication is that more than one 'receiver' can be controlled.
But if you give me a couple of days I'll have a little play and tell you for sure. One thing though - I think I'd prefer to have separate systems and avoid the consequences of fat finger action.
I'll have a little play and tell you for sure. One thing though - I think I'd prefer to have separate systems and avoid the consequences of fat finger action.[/QUOTE said:
Thanks...
I am more worried about having the incorrect remote... I'll be sticking to just one ..unlikely my autopilot would be powered up at the same time as the windlass
Thanks...
I can see your logic, but in my mind I'd envisaged using two wireless units, from different suppliers so as to have unique remotes.
Another thought though - I used three of the four channels for my ap because I have the standby button controlled too, so only one spare channel.
I've just tried it - one key (transmitter) and two 4 channel receivers. 'Pairing' the key is just a matter of applying power and then momentarily pressing a small button on the receiver's pcb, then pressing any button on the key. An led then flashes to confirm and away you go.
The first time I tried it I paired a spare receiver to the key I use with the AP, and that worked as above. I then plugged in the AP to power and operated it from the key. At that point the spare receiver stopped working. That makes no sense, so I disconnected the AP power and the spare receiver still didn't work. Re-paired the key to the spare and tried the AP again. This time there was no problem, both were working in unison. I suspect a momentary disconnection of the spare due to a very much lashed up setup...
For what it's worth, the buttons on the key work the same relays on both boards - quite important in your case Pandos!
excellent thanks for that ,,, something for a frosty day...
Hmmm that is interesting a 4 button remote controlling 2 receivers, buttons A and B for bow thruster, C and D for stern thruster.
Indeed it would but much more free space near the thrusters rather than at the helm control which is fairly crowded and not very accessible. Could make a much neater install if I could use 2 receivers linked to one transmitter.
Os you want a remote control for your boat
That's no good. There's no button for the kettle! ;)
Controls for the kettle and toaster is on the back.
The transmitter shown are locally made and are available in 1, 2, 4, 6 button with coding by the dip switches. The receivers are available in 1, 2 or 3 channel also programmable codes.
