OK hope this makes sense,the wire I thought went to the ignition switch powers the breaker box, the common lead from the 1-2 both joins a cable from the starter, where these cables join is where the relay switch gets its power, could I take the cable from the breaker box andconect it to the 3 way common lead, and then connect the other two cables from the relay up to the starter where the common connects.
I strongly recommend that you read the "Boat electrical notes" on Tony Brooks' TB-Training website
http://www.tb-training.co.uk/
Just re read your post Vic, there will be power to the breaker box, and the switch panel, that's OK, isn't it?
You dont show any power to the "breaker box" other than via this relay.
This is how a 1,2, both,off switch should be wired ( two batteries here making up the domestic bank)
As a matter of interest, what's the rationale for taking +ve and -ve from different batteries in the house bank? Is it so that drops in the interconnects leave both batteries at the same voltage?
I think the squashed spider to the left of the word "common" is meant to represent all the wires being connected together. This means the breaker panel is powered from the common terminal as it should be, and also that the relay is doing nothing at all - but the latter at least does match what was described in the OP.
So I am on the right track Pete? What to do with the small wires going to the alt from the relay? + ve,- ve they must be.
That's what I have used, just wasn't sure of what to do with the relay.If so back to square one. Nothing makes much sense to me.
Not enough info to understand what the present set up might have been supposed to do and insufficient info from the OP describing what he wants to achieve to design a new system other than to suggest that my circuit in #4 offers a simple, workable, manual system without a relay.
Yes basically so that small differences in the resistance of the wiring dont cause unequal loading and charging of the batteries in a bank. Can get very complicated with more batteries.
