chris-s
Cue much clanging and general spinnaker mayhem...
Isn’t that mandatory?
if you splice a length of bungee into the dynema you can have the bridle tight to the pole when not in use.Personally I don't like bridles on poles stored on deck, it's string or wire lying on the deck trapping dirt and getting underfoot.
I respect that other people have different priorities.
Do you mean it goes dyneema-bungee-dyneema? Is there any reason not to simply use strong bungee the whole way? Would that be too springy..?if you splice a length of bungee into the dynema you can have the bridle tight to the pole when not in use.
No I mean insert bungee into the dynema, as in inside the rope, so that under tension the dynema takes the load, but when slack the bungee contracts to keep it taught - ish.Do you mean it goes dyneema-bungee-dyneema? Is there any reason not to simply use strong bungee the whole way? Would that be too springy..?
