Do not do that. Take a down haul to the deck just behind the forestay. The other end goes to the end of the pole just behind the fitting. This takes a lot of the bending load from the pole. It also allows for duck gybes which is safer for the crew, who can do it from the safety of sitting on the pulpit with their legs either side of the forestay. A successful gybe can be completed in 3-4 seconds without the spinnaker collapsing.
An advantage is that one does not have a pole that has to be unhooked both ends & reversed. Sometimes if the sail grabs it can spin the pole round very violently with a central system. This can put a crew, standing on the deck, in an unstable position.
Twisters do not normally have a baby stayThis only works if there isn't a baby stay.
A duck/dip gybe usually needs sheet and guy on each spinnaker clew, so pole can be clipped into slack new guy.Do not do that. Take a down haul to the deck just behind the forestay. The other end goes to the end of the pole just behind the fitting. This takes a lot of the bending load from the pole. It also allows for duck gybes which is safer for the crew, who can do it from the safety of sitting on the pulpit with their legs either side of the forestay. A successful gybe can be completed in 3-4 seconds without the spinnaker collapsing.
But you have nothing to hold on to, other than the pole. With a dip gybe one is safe & secure. Having raced a 29 ft boat on the foredeck for several years, before moving up the sizes, I have been through the mill, I do know what happens. Sheet & guy are sensible, for spinnaker trim on a Twister sized boat.A duck/dip gybe usually needs sheet and guy on each spinnaker clew, so pole can be clipped into slack new guy.
End for end only needs sheets. In my experience (30 years of doing bow), on a boat the size of a Twister, end for end standing in front of the mast is preferable to going right to the bow for a dip gybe.
You sum up the reality of managing dip vs end for end on a Twister sized boat very well.Dip pole on a twister? Lol... Not a good idea. For starters the weight of the bowman on the bow is really not what you want in such a small boat. And definitely not where I'd want to be with any breeze.... And I don't think they have pulpits to sit on do they?
Then you need an extra body in the cockpit to ease the pole up, and then raise it again. So at an absolute minimum you have 3 bodies left in the cockpit (Helm, kite flyer and pit), and of course you still need someone at the mast to trip the pole. This is starting to feel like a lot of bodies for a Twister...
Then of course to dip pole you need either a comically short pole, or to be able to raise the inboard end of the pole such that it can clear the forestay, which means you need a car on the inboard end and all the attending gubbins, not just a ring.
For 10 years we raced an Elan 37 which had a dip pole setup, and that was the right setup for that boat. We now have a JPK1010, with an end for end setup, and that is the correct setup for that boat. No doubt whatsoever that end for end is the way to go on something the size of a twister.
To the OP - the 1st reply is spot on. Do that.
Twisters are not dinghies. Believe it or not they do have pulpitsDip pole on a twister? Lol... Not a good idea. For starters the weight of the bowman on the bow is really not what you want in such a small boat. And definitely not where I'd want to be with any breeze.... And I don't think they have pulpits to sit on do they?
When you gybe the pole in end for end you are standing at the mast, not the middle of the foredeck... I agree that standing in the middle of the foredeck is generally a bad idea, but that's not where you stand to gybe the pole... You also require 2 fewer people which for a 28 foot boat is really far more the point...Twisters are not dinghies. Believe it or not they do have pulpits
Bowman, when racing, the crew often get well forward to keep the bow down when going up wind.
As for a bowman going to sit on the pulpit, it is less than 4 ft further forward than a crew standing in the middle of the foredeck. Please do not tell me that hopping about on a rolling foredeck is safer than sitting on the pulpit looking aft with the furled jib between one's legs. The forestay can be grabbed at any time. Unlike when on a foredeck when there is often nothing within reach if standing. . Standing on the hatch, next to the mast, is not always an option, as one has to do a dance up & down the cabin step/deck, so the crew is forced away from the mast anyway. As for sliding the boom end up. Even my Stella was fitted with a track as standard. I would be surprised if the early wooden ones, especially the Tucker Brown ones, did not have adjustable height rings on the mast. I do not know about the Tyler GRP ones.
From memory,the spinnaker pole length on the boats I raced were all circa "J". The Op may have something longer & that would preclude certain manouvers.
However, the ideas are out there & he can decide, as can others reading the thread, which is just as important as answering the OP's question
Measuring roughly from photos, it looks like when under tension the bridles are roughly 1/3 of the length of the pole away from the pole, if that makes sense...?I'm going to rivet lacing eyes to either side of both ends of the pole to which I'll attach the 2 dyneema spans with a ring in the middle of each span for the up and down haul snap shackles.
Final question - how long and how loose should the dyneema spans be?
Not too sure of the physics...
Many thanks!
I was trying to keep my Merlin Rocket tendencies to myself.I'm surprised no-one has suggested twin-pole gybing! I can end-for-end my CO32 pole singlehanded, trying to dip-pole a Starlight 35 at the weekend with only 2 crew was not pretty.
The longer the span, the less compression on the pole but that shouldn't be a problem with the pole in the picture. Mine has the downhaul attachment about a metre below the pole and similar for the uphaul. Having the downhaul block attached to the deck forward of the mast allows gybing the pole without easing downhaul or uphaul.
