lynallbel
It's after midnight here, not a soul is stirring, we have a midnight to 5am curfew, in the big cities its from 10pm to 6am
Count your blessings
What about the night workers?
I am guessing they are working .What about the night workers?
As long as you have a legitimate reason then you can be out.What about the night workers?
Paul.Be interested to hear if your marina closes as I was booked to trial a boat for sale in your marina on Friday but the owner has told me he is not allowing and contractors or berth holders on site after Thursday.
No , there was a another agenda .Paul.
We walked to the marina yesterday and made a quick check on the boat . A key fob is needed to open the gates . Other berth holders are on site.
I suspect they are not allowed to sell boats during the lockdown? That might explain why a survey could not proceed as it is part of the boat selling process.
how do you do that without mains electric?Whats all of this cooling system draining about.
Just put a tube heater in the engine bay on a thermostat. Another near the calorifier . Dehumidifier plugged in . Open the taps and let the domestic water all pump out until the taps are spitting air then shake the shower heads dry.
One hour max?
Quite correct I have assumed shore power is available . And I believe the person I had responded to does have shore power .how do you do that without mains electric?
Not everyone has your personal circumstances.
I do nothingHi,
First time with one of these over winter - what do I do to winterise a jabsco manual sea toilet - turn off seacocks and pour diluted anti freeze into bowl and "pump" it a bit??
Is that it
On the assumption it is set up with a drainage hose draining into the (externally draining) sink and being left un-attended (monthly visits) - what settings do you/should I put it onThe Meaco dd8L is very quiet in operation - desiccant type. Thats the one I have.
Compressor type not so quiet and prone to icing in very cold snaps but may overall be longer lived
Cheap Dehumidifiers | Dehumidifier Deals at Appliances Direct
Thanks - roughly what is that costing you per week do you know - not critical just curious.I use the setting with two fan symbols and two water drops symbol. It will cut out when the required humidity level is achieved.
FYI, Don't keep switching it off abruptly, it could damage the unit, they are designed to run with the fan to cool down as part of the power off cycle.I'm just testing it by setting it up with those settings at home - it seems to be resilient to an interruption in power as with plugging and unplugging but turning the power off for app 30 mins and then back on again it doesn't completely reset despite the lights being on it hasn't come back on is that your experience??
Thanks I was only sensibly testing/simulating a couple of marina power cuts - it has in fact now just come on on its own so clearly it can cope with power cuts - good to know - "testing" over - I will take it to the boat tomorrow or Wednesday for my last visit pre my hip operation and related quarantine which all starts on the 12th op on the 19th!FYI, Don't keep switching it off abruptly, it could damage the unit, they are designed to run with the fan to cool down as part of the power off cycle.
Many years ago I enquired about winterising the Jabsco on my old boat and was told to pour a little olive oil down to keep seals lubricated.Hi,
Is that it
All the best for the op?Went to marina today 2hr round trip no changes evident at all - cars the same, boat use the same, boaters on their boats the same.
Set up heaters and de - humidifier, drained water, left engine useable for now as new antifreeze is up to scratch...........
Thats it for a while now - we have to self isolate from tomorrow night ie 7 days before op - fingers crossed it still goes ahead!
All good
Cheers
Good luck with the op. We will probably all still be in some kind of quasi lockdown when you are out so I am sure you will miss nothing.Went to marina today 2hr round trip no changes evident at all - cars the same, boat use the same, boaters on their boats the same.
All good
Cheers
