marina95
So,
A few years back I installed a brand new lofrans windlass which came as a kit with the control box and circuit breaker.
Only thing was, there was not a wiring diagram available for it. Eventually, after some head scratching I had it wired up and it worked perfectly for a year. Second year it became a little unreliable on start up (needing a little light tap on the gypsy to make it start), third year even more so. I've had the motor and gearbox off several times, it's been to a Lofrans agent here in the UK and an agent out in Greece (where the boat is located) and our several times on the bench in the yard. I simply cannot reproduce the problem.
So, this trip I'm going armed with new cables and crimp terminals determined to fix the thing.
...Oh, and of course a wiring diagram (cannot find one for the Marlin, but they look generic). Having now studied the wiring diagram I can see that there is a difference in the way that I've wired mine up.
As you can see from the diagram, instead of taking a seperate pos and neg feed from the battery to control the solenoid from the foot switches I thought it would be ok to simply take a feed from the main (16mm2) pos and neg feed to the control box.
Does the panel think that this might be the root cause of my issues? (perhaps after the 1st year the control box wasn't "new" and needed a little more amperage to operate? Mystified as to why the tap on the top of the windlass would make it go. but...
Thanks!
Thanks!
