Winderscreens leaking
Seastoke
20 Sep 2011
So a screen that looks like it is sealed like modern cars ie glued on with black stuff can it be re sealed easy or do u have take off or !
This is probably the first time (and hopefully the last) you will do the job so tape it and you will have a near perfect job, no experience necessary.
Why tape it ? The blade method gives a factory finish where as tape method doesn’t give that perfect factory finish edge that looks far better and is easier to do.
I think it depends on your skill level. I did mine last year and it takes a lot of skill to get an even small bead especially when changing to the next handle grab of the applicator. A good discussion because it gives seastoke a choice with some pros and cons.
Any before and after pics?
Did you cut back original rubber or just seal over?
I have a small leak in mine so keen to know of pragmatic options
Cheers
Cheers
Sorry no pics and my boats in Spain. My application is a bit different from yours in that my screen is fitted with a rubber seal but the problem is the same. I just cleaned behind the rubber, made sure it was completely dry, taped up and sealed between the glass and rubber and took the tape off straightaway.
I should have replaced the whole rubber seal which people on here say is easy but I’d rather go boating and the job was a good’un
DavidJ
That's great - exactly my issue; Targa 40 windscreen is a s#d and been told not to be taken off!!
I did a few patches this way and had wondered about doing the whole thing - so now I will
But .. hows yours lasted ?
Cheers BT
DavidJ
Cheers BT
I did it about 5 years ago with standard sika. Now I’m using the right stuff I would expect at least another 5 years.
