dulls
N/A
Balance is the issue. I think the aries no 5 was more forgiving of my bad trim! I think a hydro would make me concentrate.
a comment, you may hear that wind vanes are only worth bothering with for long legs on the same course, but I engage the Aries at any possible opportunity, even if it's just a couple of miles, why not?
Interesting thread.
Nobody seems to want to remove their vane and rely on an autopilot.
I have a Sea Feather on my boat, but it has been out of service for years and I use a tiller pilot instead.
When the Sea Feather worked it was wonderful, but I found it extremely difficult to set up. It had a tendency to get into a funny state where the water vane was right over one way and the tiller was right over the other but the boat didn't turn back on course and simply sailed sideways in the wrong direction. I think it was a mixture of an unbalanced sailplan (rolling away some jib helped) and huge sensitivity to any slack at all in the rope + chain control circuit. Unfortunately you have to have slack in that to get the chain over the tiller drive peg, and that was just enough to mess things up.
I'm not giving up on it, but I think it's going to take a day or two of careful experimentation to get the installation right. The makers were very helpful and offered to diagnore from a video of it (not) working but closed before I could get that done.
Normally, that is just a case of putting the peg through a different link in the chain to bring the oar back into the centre & give the vane some weather (or is it lea?) helm to start with. Slack is not a problem on the lea side, only on the pulling side, so you work the peg along the chain to suit. The boat will pull itself back up to windward so the gear does not normally have to pull so much on your "slack" side unless running down wind. Then you usually need a more positive response, but it depends on a host of factors.
I prefer the Pacific Light tiller chain grip as it has less slack in it than the Sea Feather. You could put some rolling hitches in the control lines so that once the chain is on you can set it up tight afterwards. You don't want it drum tight, but I do find it works better with a lack of slack, though there are plenty of Youtube videos sailing successfully with slack.
You should be able to get the set up working well - ie it is a matter of fiddling with it all (including sail plan) rather than deciding there is something about the set-up which makes it not work on your boat.
As a matter of interest how much rake do you have in your mast? Do you typically sail with a neutral helm, or lee or weather helm?
I only have experience of the Navik, which worked superbly with my Vega. I shall fit it to the new boat (10m, 6t) and report back...
Can you get to Dartmouth? If you can I am sure Lee would come sailing with you and sort it out. re slack in the chain, not really needed as you can un-clip, put over the tiller and re-clip. On occasion, I have found that a useful way to engage / un-engage.
Interesting, may I politely point out that you don't need to accept play in U/J's, and they are cheap, as are shaft bushes.I have a Hydra Auto steer trim tab on my twister. It's purely ornamental as there is so much slop in the shaft to the tab that i can move the input arm hard over without the tab moving!!
That's not to say the system is no good but i'm working on a new shaft drive to remove the two universal joints and replace with a single bevel gear. It will be a winter project and the last chance for the Hydra. If that doesn't fix it it's getting replaced by a solar panel.
Very interesting, why Harken in particular? Is it because they are ball or roller bearing instead of plain bushes, to reduce friction?The lines need to be tight. but not too tight! Harken blocks a necessity.
It's a point I was intending to optimise on my Aries tiller installation (with 4 turning blocks...)
