BrianH
I have the Air-X with a peak output of 400W, which was then discontinued (I think) when they brought out the Air Breeze at only 200W. I think it was thought that the Air-X had too much rotor resistance to start at lower wind speeds so potential output was sacrificed for easier starting and faster rotation at lower wind speeds.Thank you for link.
I guess it is Air breeze marine.
One questuon: Air X, Air breeze, Air 40- are these "the same"?
My Air-X will start to rotate at 8 knots and be producing significant amps from 10 knots or more. I have had it for 12 years but would never consider replacing it for the Mediterranean where wind is often too little, the sun is so reliable and solar panels are now so cheap.
Edit:
I now see that I was right about the Air-X being discontinued when the Air Breeze was introduced but re-introduced in 2012:
"The Air-X Marine was relaunched by Primus Windpower in 2012 due to high demand. The Air-X has an incredible 400w output squeezed into a small lightweight body with built in charge controller. It is recommended in areas with higher wind speeds and is specifically designed for use in marine environments whether on yachts, buoys, coastal or industrial installations."
