artemis07
More from Artemis07
The controller does have an " electronic break" which slows the generator. This is activated by a switch. As I understand it when the turbine speed increases and the generator is in danger of overheating the load is removed. In my experience this causes the turbine to increase in speed, this happens with winds over 40 knots.
We had no time to activate the electronic break or rig a mechanical break (a line). The controller's 20 amp fuse blew but not before the controller was burnt out. The turbine was spinning at several thousand rpm. The blade tips were travelling at speeds approaching Mach 1 where aerodynamic forces on the blade tips are extreme. The boat was heeling at up to 80 degrees at times, to say the airflow was turbulent is an understatement.
Marlec say the blades are tested but what does that mean? Are they tested in a wind tunnel with a steady airflow or in real conditions. Marlec say the blades are tested to 10 times the maximum design rpm, but don't say what that is and when it will be achieved. Their graphs only go to 40 knots. 10x maximum design rpm would put a huge load on the blades, 100x the design maximum load.
For those of you who think I am having a moan it is far from the truth, I love my 913 and will be using it for many years to come. I would just like to point out that they are not indestructible and if the blades shatter like ours did it could prove fatal.
