sutton sailor
Can the forum advise? I have a variety of automotive greases. Do I need to use anything special for my Winch which is single speed Antal , I also have a tub of stern tube grease.
It has all been said above. Lightly oiling and never greasing the pawls is the most important part. I have used Blake’s seacock grease lightly in past because I had alot of it. Some good YouTube videos around.Winch grease is pretty light weight but waterproof.
I do use Lewmar Winch Grease. But the trick is to use Very Little.
Might sound daft but I use a make up brush 1/2 inch - and keep this only for the winches. Clean off any previous lubricant and muck - then Only use a light smear.
Don’t forget light oil for the pawls. Don’t use grease on them.
It might have - but it might have dissolved the rollers, too as the cage is some sort of plastic.Yes. As post 10 says and I forgot, really regular servicing solves alot of problems. And winches are easy to work on.
Really surprised that some solvent immersion for a few days could not release even rock hard grease from bearings. I’d have liked to see some photos or video of those winches.
Oh I didn’t know bearings used plastic cages , my mistake. Sounds like you really did exhaust every avenue before replacing bearings, sodium hydroxide etc really is caustic and nasty (potentially) and if you added pressure you really went to alot of effort.It might have - but it might have dissolved the rollers, too as the cage is some sort of plastic.
The most effective was a degreasing setup that used a caustic solution under pressure. But even that didn't get it all out.
I take no credit - it was my brother who tried the degreasing setup!Oh I didn’t know bearings used plastic cages , my mistake. Sounds like you really did exhaust every avenue before replacing bearings, sodium hydroxide etc really is caustic and nasty (potentially) and if you added pressure you really went to alot of effort.
Brake fluid can be quite an effective solvent for this sort of thing, makeing quite a good carb cleaner, for example. Its water miscible so a follow-up boiling would be possible. I havn't tried it on stuck winches and dont of course know how it would treat the plastics, but its compatible with the rubber parts on brakes.Oh I didn’t know bearings used plastic cages , my mistake. Sounds like you really did exhaust every avenue before replacing bearings, sodium hydroxide etc really is caustic and nasty (potentially) and if you added pressure you really went to alot of effort.
In fact, Antal is the one manufacturer that recomends grease on the palls. Look it up, any model. Antal grease, BTW, is thinner than most.Winch grease is pretty light weight but waterproof.
Brake fluid is a glycol ether (there are several formulations) and can be rough on some paints and adhesives, but I think phenolic is pretty safe. But I would NOT heat it, since it does not get an A compatibility rating. It is not compatible with all elastomers (rubber), just those used in brakes.Brake fluid can be quite an effective solvent for this sort of thing, makeing quite a good carb cleaner, for example. Its water miscible so a follow-up boiling would be possible. I havn't tried it on stuck winches and dont of course know how it would treat the plastics, but its compatible with the rubber parts on brakes.
I agree! A tube of Lewmar grease doesn't cost that much, and lasts years. Why risk it?I bought a tube of I think Harken winch grease when I bought the boat 17 years ago.
One uses so little, I'm still using the same tube.
Harken won't retire on the amount of winch grease used.
Winches are such important items. Get and use the propriety grease. Not a great expense in sailing.
Great reminder to me, I must service my winches
