wifi on board
cinnabar
New Member
8 May 2002
I am looking for advice for improving wifi signal on board. Thinking of a Ubiquiti Bullet ac with PoE. Any one using this? Advice re dual band antenna to go with it? How easy is it to configure if you are a wifi ignoramus?
I had a bullet. Didn't work for long - reset button very poor design and breaks (seems a common problem). Now just use mobile and everything links into it. Yet to find a decent marina WiFi.
MDL WiFi is pretty good most of the time. We have recently moved to a Premier Marina and, while the signal is good and speed very reasonable, the service is useless for us because it is restricted to a web proxy service - no other ports passed through like SMTP, IMAP, FTP, Telnet etc. etc.
We use a 4G data sim in a Netgear 4G router.
You don't need the dual band Bullet. 5 GHz is very rarely (if at all) used in public Wifi access points, because of the limited range and penetration compared to 2.4 GHz. Stick with 2.4 GHz. We're very happy with the Bullet performance, although you will end up having to run an ancient firmware, because a lot of networks still use WEP and WPA(1), which Ubiquiti pronounced (rightly) outdated and (wrongly) removed all support for from firmware some time ago.
For an antenna, a fibreglass omni around 8-12dB should do.
Marina Wifi is indeed regularly broken (although with the bullet you can select the one working access point out of the bunch), the uplink saturated to the point of being useless and sometimes even charged extra despite all this. However, with the Bullet we can pick up restaurant and hotel wifi from further out, and some of our best connections were at anchor, picking up free beach/hotel/bar wifi, or buying a round of drinks to get the password.
Configuration for a Wifi ignoramus is not trivial, but you can stop being one and learn some things - much like sailing!
I think your comment re 2.4/5 GHz may generally be OK, but when we were based at Cap d'Agde they introduced a 5 GHz system because there were so many apartments with 2.4 GHz surrounding the marina. Of course, following a well-established tradition it didn't really work ... ...
As per previous posts, I've tried to improve the marina signal by various methods but now use my phone tethered to my laptop. The only problem is that Windows 10 updates regularly try to rape my data allowance if I'm not paying attention.
I have had one for about 7 years. It works well. I have been able to pick up wifi from about 3 miles away. Mine is interfaced to a netgear router to provide wifi on board. Use the bullet as a DHPC server.
I am aware that some have problems with the cable gland and have solved them using self amalgamating tape.
Thanks for the reply. My consideration of the 5GHZ was more for future proofing although it sounds as if that is not realistic, and because less crowded if you can get a signal. Use would be more for picking up local hotspots at anchor, I think than anything else. Always happy to learn if materials available!
Thank you - Was your's dual band? Will definitely think about a router if can get wifi aboard.
