cinnabar
I am looking for advice for improving wifi signal on board. Thinking of a Ubiquiti Bullet ac with PoE. Any one using this? Advice re dual band antenna to go with it? How easy is it to configure if you are a wifi ignoramus?
Yes to pick up marina wifi and hotspots.Is this for marina wifi? I find I get much better connectivity by tethering my laptop to my phone.
In my experience, almost all marina wifi is dire.
You don't need the dual band Bullet. 5 GHz is very rarely (if at all) used in public Wifi access points, because of the limited range and penetration compared to 2.4 GHz. Stick with 2.4 GHz. We're very happy with the Bullet performance, although you will end up having to run an ancient firmware, because a lot of networks still use WEP and WPA(1), which Ubiquiti pronounced (rightly) outdated and (wrongly) removed all support for from firmware some time ago.
For an antenna, a fibreglass omni around 8-12dB should do.
Marina Wifi is indeed regularly broken (although with the bullet you can select the one working access point out of the bunch), the uplink saturated to the point of being useless and sometimes even charged extra despite all this. However, with the Bullet we can pick up restaurant and hotel wifi from further out, and some of our best connections were at anchor, picking up free beach/hotel/bar wifi, or buying a round of drinks to get the password.
Configuration for a Wifi ignoramus is not trivial, but you can stop being one and learn some things - much like sailing!
Thank you - Was your's dual band? Will definitely think about a router if can get wifi aboard.I have had one for about 7 years. It works well. I have been able to pick up wifi from about 3 miles away. Mine is interfaced to a netgear router to provide wifi on board. Use the bullet as a DHPC server.
I am aware that some have problems with the cable gland and have solved them using self amalgamating tape.
Thank you, will investigate.You could look at the Mikrotik Groove AC. Costs a fraction of the price of the Bullet. Is weather proof, and does the same job.
