Do you have it on both engines ?
Thanks, pan. That was my first thought too. I have replaced both header caps already and the leaks continuedClearly looks like some cleaning work was required, we haven't had any issues with leaking fresh water coolant, although I am aware that it is very important to ensure the header cap seals are in good order (we carry 2 spare caps) the MAN system is pressurised & it's vital there is no leakage.
Indeed.And this is a pic of the gearbox heat exchanger. Surprised that so much debris got through the strainer
Indeed.
Weird as it might seem, I would even dare guessing that those weeds actually grew inside the heat exchanger, during extended periods with engines not running...
...but what do I know?![]()
Yes indeed. And I will be adding a litre of garden weed-killer each time I do it now!Of course the next question in my mind is what the seawater circuits in my generator and aircon units look like. Jfm's idea for a freshwater flushing system is looking like a very good one
LOL, that's a massive understatement, if I've ever seen one.I am the mere spanner monkey here.
Indeed.
Thanks Bandit appreciate the input, actually in pic 3 the engineers reported this was not weed, but some sort of metallic shavings, which we never identified where they came from (could only assume debris from engine build!) and certainly had us scratching our heads. The anodes were quite corroded and have been replaced, which again brings us back the necessity of the scheduled MAN recommended cleaning.
