Daydream believer
So why are so many propellers on shafts on a taper?Good question, I have also often wondered.
Compression fitting on something that is tapered seems like very bad engineering.
tapered?
Somewhat different! Something to do with rotation?So why are so many propellers on shafts on a taper?
Totally different. The traditional clamp is compressed around the tapered post with nothing (short of friction) to stop it from rising, while the prop is compressed onto the taper by the nut, which counters that movement.So why are so many propellers on shafts on a taper?
Stainless steel is a poor conductor... When the lugs are stacked, the majority of the current passes from stud to lug to lug etc but there is little contribution from the stud and the stainless washer below its head. Brass and copper are better but subject corrosion.
Yes it would but if the bolt conducts, an electrical path is provided both sides of the connecting lug.The material that the fastening is made of (in the picture that you quote) is irrelevant. Current passes through the post, through the lug/s and along the copper wire, nothing has to pass through the washer and bolt/nut. The bolt could be made from non conductive material and it would still work just fine.
What about the screw that holds the cup type connecting piece to the pole. That fastens the connector down onto the post. I have, in the past, had to use a lever to force it upwards after the screw had been releasedTotally different. The traditional clamp is compressed around the tapered post with nothing (short of friction) to stop it from rising, while the prop is compressed onto the taper by the nut, which counters that movement.
Agreed but the polarising is to do with the diameters not the tapers.Interesting question! (Never thought about it)
"Essentially, we have a tapered negative post and a tapered positive post that are slightly different sizes. So, the positive terminal is slightly larger than the negative terminal. This was built as a safety factor so that the cables couldn't be easily interchanged on vehicles."
Don't overlook proper battery terminal set up
Yes, the screw creates a compressing force that fastens the clamp to the post. But because of the tapered shape of the components, there is also a sideways force created that pushes the clamp upwards, which decreases the clamping pressure.What about the screw that holds the cup type connecting piece to the pole. That fastens the connector down onto the post. I have, in the past, had to use a lever to force it upwards after the screw had been released
Well I understand that a Tapered connection is firmer than any parale connection , so guess Batteries have tapered posts ; they are also tighter than paralel posts
Curious why the "WOW" to post #11 ?
Drilling, tapping and fitting a stud is a valid method, often used for repairing damaged battery posts.
Making the post "square" only makes it the same as millions of Ford batteries.
The No 2 morse taper in the tailstock of my lathe holds a Jacobs chuck. It is held by friction alone. No draw bar to tighten it. I just push it in & it grips. I can put a 15mm drill in it & it will drill into steel without slipping. The morse taper does not rotate The steel it is drilling does.Somewhat different! Something to do with rotation?![]()
Good question. Tapered posts have often caused me problems.tapered?
