Talulah
As a follow up to the original question you could ask "Who uses a Road Atlas instead of paper charts?"
Yup, Bart, I'm well aware of that and it's not just in Croatia. I've found many anomalies on electronic charts, even brand new ones, in Med cruising areas. As I said in my post, whilst I now use the electronic plotter as my primary nav tool, I always consult paper charts before plotting a route and keep the paper charts open next to me when I'm helming the boat to cross check whether the hazards shown on the paper charts are depicted on the electronic charts. I still can't bring myself to rely completely on electronic charting and besides that, I like paper charts in the same way as I prefer newspapers and paper books to electronic versionsI
@Deleted User,
be warned though,
we all know that the electronic charts are not alway's up to date and not 100% accurate,
ones on a trip in Croatia there was a marina, but NO mention on the plotter,
(don't remember exactly, Sibenic area IIRC)
on another trip our track was over land , at least on the display,
(over island to be correct)
I plot on chart first then transfer to plotter and keep chart to hand. Always have charts on board. I enjoy the paper work to be honest.
L
'course not. I'm pretty sure they had also paper charts on Concordia bridge.er...are you Francesco Schettino?
Yes I have. In any meaningful passage, I always keep a notebook running in parallel (totally separate from boat instruments) with its own GPS dongle and charts.Seriously though, have you considered what you would do if it went on the blink?
Paper first plotter second-or plotter not at all (always afraid the thing will throw the towel in)
Blimey, I didn't think those were still around. Excellent piece of kit but I assumed they'd all been replaced by electronic plotters these daysWhat works beautifully for my way of navigating is a Yeoman, which uses an NMEA feed from the GPS to let me instantly plot my position on the chart, or display range and bearing to any feature I put the puck over.
I used to think that until one day a few years ago, one of my engines stopped. I found out later that the alternator was malfunctioning and was discharging the batteries connected to it. On many engines, the stop solenoid is positively energised to stay in the open position (in fact I think it may even be required by regulation) so no electricity causes the stop solenoid to close which means no fuel and no engine.steer manually and fully control the engines, 'cause on my boat neither need electricity to work;
:...though I actually think that you have higher chances of seeing your paper chart blown overboard by a wind gust.
And if THAT happens, have you considered what YOU would do?
Now, that's what I call a sound emergency plan!Send the SWMBO into the water to fetch it, of course
Silly question. Send the SWMBO into the water to fetch it, of course![]()
The current boat only has one plotter, but the next will have two. For now, it depends where i'm going. I might just aim for the next buoy, i might click on a spot on the plotter and "go to", or i might plan a route on the PC and send that to the plotter.
If the plotter failed than i'd use the laptop that has it's own software and charts and gets its GPS data from a hand held Garmin GPS.
If the laptop failed, i could just use the hand held GPS. Or, i could use the hand held GPS with paper charts.
Last resort would be to use the paper charts with hand held compass etc.
The very last ditch backup is to take the hand held GPS and VHF in the grab bag, to the life raft.
If that all fails, the Gods truly are against me and i may as well tie myself to the boat as it sinks![]()
I'm sure someone will belong shortly to remind you of the versatility of carrying a sextant.
...In any meaningful passage, I always keep a notebook running in parallel ....with its own GPS dongle and charts....all people onboard have a GPS in their mobiles...
And if THAT happens, have you considered what YOU would do?![]()
