xyachtdave
Maybe a little voice in someone's head says "Sometimes a big burst of power will get you out of trouble"?
More throttle is often applied in these situations rather than less so that's a possibility.
I once saw someone hit a fortunately well padded dock in a fortunately inflatable RIB at speed that could probably do that sort of damage if it had been fibreglass and unfendered steel: turned out the gear linkage was not connected properly so remained in forward when the helm tried reverse. What do you do when going too fast ahead? You give it a blast of reverse. If gearbox is stuck then you actually go faster. What if your automatic reaction? More reverse!
Exactly that situation prompted my query! I've been on a boat with a fancy prop that was adjustable and feathered etc but it only gave forward propulsion coming into Eastbourne lock when some astern would have been useful to stop the boat. Had to get it lifted to resolve.
I might guess: a learner learning.
If that's the case one would assume the learner learning had an instructor nearby and within reach of the throttle? I wonder if one of the crew stood on the throttle or similar at the wrong moment.
