Which Stove top toaster?
iangrant
By the Sea
Jim
I tried the trianglar one some time ago and sadly it wasn't a lot of cop, on top of that it rusted almost straight away.
In the end gave up and bought an electric toaster and an extension lead.
Thankfully I've a grill now on the stove.. Still use an electric toaster when on shore power though.
BTW if you can invent a way to make toast on an airliner you'll make a fortune..
Ian
Grandad
2 Sep 2004
Fylde coast (Lancs)
Jimbouy.
On our first boat, may years ago we only had an ancient 2 burner primus stove. The "toaster" that came with the boat was just a thick piece of steel plate.
This was heated on one (for single slice) or both (for two slices) burners till suficiently hot (initially some trial and error involved) then burners off & toast made. It was supprisingly effective, but did take some effort to keep rust free untill we started to wipe it with a spot of vegitable oil.
P.S. it could also be used as a griddle to fry eggs & Burgers.
Cheap and cheerfull it was, BUT IT WORKED for us.
Good luck.
Bob.
We don't eat bread anymore but when we did our 650watt toaster worked fine through the inverter and because it's only on for minutes didn't cause a power crisis.
We've had various stainless hob toppers from discount chandlers but none has been much use.
Steve Cronin
iacle
22 Jan 2003
Isle of Man
Had a look at that Argos toaster on their website - looks exactly the same as the one we got from Millets about 3 years ago, which is still going fine. You have to adjust the flame & move the bread around to toast it evenly, but it does the job, it's cheap & it doesn't rust.
jimbouy
21 Aug 2003
Sailing.. Solent. Home..Bucks
www.bluemoonlight.co.uk
Steve,
I haven't gone down the route of having a "big" (in terms of wattage) inverter on board. I do have a 300w job which I can use for various rechargers... cordless tools mainly and will also run my trusty Bosch scrapper.
I don't think I could justify the cost of a larger one against its usage, but it's worth keeping in mind.
Jim
Richard_Peevor
28 Nov 2002
Swansea, UK
Botheras - did it taste funny with the meths??? When I saw this post I thought I'd ask about taste with the origo 2 as I have held off buying the toast rack as I presumed it would only work (nicely with no smell) with gas.
Shantyman
15 Oct 2004
Humberside, U.K.
I used to do toast quite successfully years ago on a primus stove using a flat circular perforated device with folding wire supports for the toast.
sorry can't remember the name but I would think any camping shop might be down by the head with such devices.
Happy munching.
Shantyman.
maxi
8 Nov 2002
Hampshire
Towsure do one at about £2.50 or so (£7.99 in the swindleries), it's the smallest, cheapest & most effective one that I have come across. Only does one slice at a time, but is really quick.
carloyn
16 Jul 2010
Toaster
Hi all
A friend from Canada recently recommended this toaster to me. I ordered and tried it, works great!
After looking at all the options for diffusers, including the italian ones, I found a diffuser I would recommend. It can also be used as a toaster (which uses far less energy than using the oven or broiler to make toast). In fact I have one at my home as well! I use it almost every day. It's quite well-constructed and solid. See: http://www.argau.com.au/
Anne Stewart, Toronto
CS 33 Grey Wolf, in Florida
www.annestewart.ca
lustyd
27 Jul 2010
My preference has always been to butter first then "toast" in a frying pan next to the bacon :)
