David of Essex
Volvo fuel filter part no 861014 10 micron from volspec. Sorry can't be more help only ordered from them last year.
David
David
Paul,
Just a little confused, let me do some mind reading:-
I think you may have transposed #'s FS1242 not 1224. Do I assume you have 1-14 filter head which originally used FF105c and you have upgraded to the Fleetguard FS1242B/Racor S2301 with the clear plastic bowl/drain at the bottom?
Further upgrade of FS1242B is the FS1015 less expensive if you re use existing plastic bowl or FS1015B complete with new bowl.
David
Id like to have racor 2040 housings or separ 2000/10 flat panel type filters.
Anyway think shes going on the market now in favour of hard top s cruiser.
Latestarter. Thanks for the time and trouble you have given. The price from volspec for filter 861014 last year was £21.96 inc vat. I take it you are saying, a rock stopper would be advisable in front of my pre filter. If so what size and is the make coalescing.?
This is the pre filter as fitted to D4 260hp engine
I would favour the Racor, those Separ are more awkward to change with those four bolts to remove the tops and the elements are nearly half the price aswell.
Have removed a few of the ff105 fleetguards and replaced with Racor as they just not really suited to this kind of use.
I am absolutely astounded, have you ever read a technical data sheet!
However admitting to ripping out FS 10c in favour of Racor 500 MA is plain crazy.FS105c has greater Beta flow rating than the Racor 500MA. I admit builders spec the FS105c on a knife edge, but when boat already has a 1-14 filter head you could have upgraded to the Fleetguard FS1242B/Racor S2301 with the clear plastic bowl/drain at the bottom together with further upgrade to the FS1015B, probably just over £25.
How much did you 'take' the poor bloody owner for, certainly more than £25, to give them somthing light years inferior in terms of Beta flow, boat owner left hanging out to dry just because you cannot be bothered to read, let alone understood a bloomin spec sheet.
The main fuel filter fitted to the port side of the D4 has an electrical connection fitted to the base of the filter. I take this to be the WIF sensor you are referring too. No electrical connection to the pre filter.
