Which Propellor ????
gonfishing
21 Jan 2003
Hi
Due to the design of my boat I tend to prefer mooring /going along side on my port side, as I find it easier and safer. So what Propeller should i fit when replacing the outdrive, left or right hand, and why????
Will it really make any difference ???
rgds
julian
<hr width=100% size=1>It will be O.K soon, nothing else can go wrong,Honest !!!
stamfordian
28 Dec 2001
LINCOLINSHIRE
Simple answer if it works ,don,t fix it,but the direction of the prop depends on the rotation of the engine(although you can reverse it on the outdrive),there is a theory mentioned on lanson,s post that its to stop single proped boat,s leaning due to prop torque.ie the relationship bbetweenthe direction of the prop and the helm posistion.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/stamfordian>http://www.arweb.co.uk/argallery/stamfordian</A>
martynwhiteley
18 Aug 2001
North Lincolnshire
Wouldn't think it would make much difference once your used to it, whichever was chosen.
Since RH is the 'default', best to stick to that I would have thought, so spares are more 'off the shelf'.
And of course make sure both the leg and prop are the same at least!
<hr width=100% size=1><font color=blue> <A target="_blank" HREF=http://www.mboat.org>http://www.mboat.org</A></font color=blue>
David2452
6 Jun 2001
London & Fambridge
Shouldn't make any difference as you can tuck your stern in using a burst of reverse while pointing the drive to port, this has far more effect than any "paddle wheel" from the prop.
David
MapisM
11 Mar 2002
For mooring port side, RH prop makes your life (slightly) easier.
But when you leave your mooring, then it's the other way round.
On a single outdrive boat, I'd rather consider a duoprop, if manouvering is your major concern...
...and you don't mind a somewhat higher cost.
