VicS
There are some minor benefits, although I dont remember if any one of them was the reason I wired it the way i did .Any particular reason to have its own switch for the compass light?
Most usefull is that it can be used to illuminate the cockpit floor ( and the pee bucket
My system is designed so that I cannot display an "illegal" combination. No steaming light on with the tricolour, no tricolour on with the side lights. I am still responsible for having the right lights on for the activity though.In the end I just put seperate switches on all the lights and I then can choose the right combination for whatever I am doing.
If I did it again, or if I open it up for some reason, I think I would not put the negative through the main switch. I would then use the redundant side of the switch to connect the engine ( outboard) to the incoming positive from the battery.
