oilybilge
I have a Beta Marine 20, about six years old, not used a great deal, and it often runs at low revs. Is there any advantage/disadvantage in using 'premium' forecourt diesel over the regular sort? Cheers.
@Refueler will be along later with some technical explanations.I have a Beta Marine 20, about six years old, not used a great deal, and it often runs at low revs. Is there any advantage/disadvantage in using 'premium' forecourt diesel over the regular sort? Cheers.
Switched to Premium, and a weekly Italian Tune-up, issues gone.
My Beta 20s do fine on red diesel, though the mechanic who looks after them tells me he's seeing more fuel problems - bug, etc since the addition of ethanol, which seems to be pretty hard to escape now.
You might do better running it a bit harder.
. . . He recommends a fuel treatment with every fill up and a dose of bug killer once a year.
The ones I was recommended are by Marine 16. The bug killer comes in a 100ml bottle, which will do several treatments unless you've got a bad case of the bug, and the treatment comes in a 500ml bottle, and my tanks (around 100l each) take 50ml each when I fill up.Are fuel treatment and bug killer different things?
What is this 'fuel treatment', and do I need some?
I tried premium petrol in my car and it made no difference whatsoever.I read an article in the motoring press a while back that said whilst premium petrol was definitely a thing (less ethanol, higher octane) premium diesel was a marketing ploy.
I've owned a few cars with high performance engines and they are tuned for higher octane fuel. I remember my gf Dad had a Mark 1 Lotus Cortina that was a pig to start unless it had 5 star petrol in it.I tried premium petrol in my car and it made no difference whatsoever.
However the lawnmower and the very old two stroke outboard like it very much.
I have a 2003 Smart Roadster, and I use premium (E5) fuel in it because although standard (E10) fuel is supposed to be ok, I've heard contradictory advice on whether it can cause damage to seals etc. But as the car predates the extensive addition of alcohol to fuel, I prefer not to risk it.I tried premium petrol in my car and it made no difference whatsoever.
Good advice to run carburettor dry but as the engine starts to die operate the choke. That will usually make the engine run for a bit longer and almost completely empty the carburettor.I've owned a few cars with high performance engines and they are tuned for higher octane fuel. I remember my gf Dad had a Mark 1 Lotus Cortina that was a pig to start unless it had 5 star petrol in it.
Unless your engine is designed for it, you won't feel any difference.
For your garden and two stroke engines, use the least ethanol petrol you can find and stop the engines by turning the fuel supply off so the carbon runs dry to prevent it gumming up.
Is it rumour or fact that red has the same level of biodiesel as white forecourt?I've always used red diesel, but given that it now contains biofuels and isn't any cheaper there seems little point.
My preference is to have the freshest possible fuel added in the spring.Incidentally, I asked if, with current diesels, it was still a good idea to fill the tank for winter.
According to various fuel suppliers on the Internet the only differences between red and white diesel are the colour and the tax.Is it rumour or fact that red has the same level of biodiesel as white forecourt?
