Which fluid for this compass?
Reptile Smile
8 Feb 2012
Bristol
Sorry all, tedious topic. There was a thread fairly recently IIRC in which someone said the correct fluid to refill a compass depended on the make & model.
I need to refill this one: IMG_0471.jpg
What do I need and where can I get it from..?
Cheers
Some info from another thread, hopefully heading off any "I gave my cow turpentine" advice:
I thought it best to start a new thread about my Suunto Compass, which has leaked all of the fluid.
Suunto replied: "Please be informed that compasses over 10 years old cannot be repaired anymore. If fluid is leaking out, refilling the compass may not be a permanent solution. Mineral oil is used in filling the capsule. We have used liquid known as Isopar M ..."
I've just had an interesting reply from Barry at compass repairers BPSC Marine:
Isopar L (compass fluid we supply) is specific for the job! White Spirit is used for cleaning paint of brushes! Lamp oil, if you knew the number of compasses that come in with that inside that I just throw away because it ruined the internals. Below are the fluids I have had in because someone told someone else it would work!!
Olive Oil
Baby Oil
Sunflower Oil
Kerosene
Pink Paraffin
White Spirit
Clear Massage Oil (enough said)
All of this compasses were marked ‘oil fill only’
I need to refill this one: View attachment 37633
Cheers
Very possibly the original fluid was one of a range of Esso Bayol fluids which is no longer available. I know it was used in Plastimo compasses.
Different people will suggest various fluids including baby oil, white spirit, lamp oil, gin, vodka etc
If you do not want to risk terminally damaging the compass by filling with the wrong fluid then the only sound advice is to contact a compass repairer eg forum contributor BPSC marine http://www.bpsc-marine.co.uk/
A new Contest on ebay is £129 inc del.
check ebay for a cheaper deal on a compass, fixing that one you have will be a waste unless you spend very little, the diaphragm will be shot will that amount of liquid gone
Ok, more than half the cost of the boat then... ;-)
Thanks all - much appreciated
Same compass i think I refilled with "Barotine" lamp oil and still looks good 3 years later (I did get new covers as well)
Barry serviced my Ritchie some 7 yrs ago & by the sound of it it cost more than the Ops boat :ambivalence:
Empty the old stuff out and refill with white spirit - I came to this solution years ago as a result of several threads on this forum and it works well for very little outlay.
I was debubbling an old Sestrel Radiant a couple of years ago and phone SIRS for advice. The very helpful woman there said "Take the plug out and have a sniff. If it smells alcoholic, use gin. If it doesn't, we'll sell you some Bayol substitute".
Gin it was.
... fixing that one you have will be a waste unless you spend very little, the diaphragm will be shot will that amount of liquid gone
Exactly! The liquid has leaked out because there's a fault in the compass. You need to fix the fault before refilling it.
Cheers
Definitive answer...Johnsons baby oil from your nearest Chemist, and get a pipette from them to decant it.
I have the same compass and did the same job years ago.
In my case I foiund a crack at the filler, unscrew that and pump the current fluid into a holding jar, enough to reduce the level to clear the crack.
dry the crack out as best you can and seal with eg araldite.
pipette the original fluid back, andd top up with baby oil . They smell identical ( my wife recognised the smell of the original.)
The fix will be as good as your repair.
