kcrane
Totaly new to dehumidifiers and need to buy one asap as the boat today was very cold and moist in the downstairs cabin.
Is the Meaco DD122FW MK 3 the latest version ?
& does it:
- Work in low temps
- Can you adjust it so it only comes on at a certain humidity
- Does it have an external drain & come with a pipe to connect to it
- does it have a timer built in
- where in the cabin does it work best, on the floor of level with the sink
Hope you can help before I place an order.
Any one found one cheaper that £159 ?
Chris
We bought one a couple of weeks ago.
- Work in low temps - Not entirely sure, but as it is a desicant variety I believe it does
- Can you adjust it so it only comes on at a certain humidity - Yes, there is an Auto setting, plus a low one and a laundry one (which is aggressive)
- Does it have an external drain & come with a pipe to connect to it - yes to both
- does it have a timer built in - no, it switches on and off with the auto function
- where in the cabin does it work best, on the floor of level with the sink - we have it level with the sink so that it can drain easily
The other question is, if the power goes off, does it come back on, or sit waiting for human intervention? Answer it comes back on.
