Turnbuckle
Moody 30 needs an auto bilge pump. Any proven suggestions? Thanks in advance.
Thanks. Submersible with built in float switch it is. Any reccomended make? Can I pair the output with an existing through hull and a one way valve or will I need a new through hull?Either a submersible that sits in the bottom of the bilge or a diaphragm type away from the water as self priming.
The submersible type can have a built in float switch.
If it's a just in case pump I would fit a submersible type with built in float switch as it would last a very very long time if never used and easiest to fit ?
Can a float switch jam open with trash and burn the pump out also?Steer clear of Water Witch electronic switch, I had one fail "on" and burn out the pump. Google then told me that this was not uncommon.
justThis is the bilge switch I use and not had a problem for over 10 years
Hydro Air Switch | Xylem
The previous noddy donkey bilge switch would need to be replaced at lease every year.
I would not use a pump that includes a switch as if the switch fails you then have to replace the pump as well if the switch can be bypassed and fit a seperate switch anyway.
just
looked but can't see how that works. Would you explain if poss plz.
+One for that float switch. Having had many open boats on moorings have got through a fair few pumps and switches over a lot of years.This is the bilge switch I use and not had a problem for over 10
Cool.ThankyouAs the water rises in the bilge and over the bell it precedes the air in the bell and up the pipe into a pressure switch in the upper part which is mounted high above the max water level.
This is similar to how a water level switch works in a washing machine . In fact you could use a washing machine water level switch
Agree, this type is very reliable although my one is a washing machine water level switch bought for £10 and connected to a length of 13mm bore hose that goes to the bottom of the bilge with the switch way above. You will nerd a relay to cope with the current demand of the pump although I just use mine for an alarm.As the water rises in the bilge and over the bell it precedes the air in the bell and up the pipe into a pressure switch in the upper part which is mounted high above the max water level.
I have float switches ... as you call Noddy Donkey type that are years old and still working fine ......
As regards pump with switch in one units ............ maybe take another look - as most have detachable filter / float switches and can easily be wired to a separate switch after removal of built in.
In fact you can even leave the old floaty in and just wire in another. Done that before.
Just my experience other design/manufactures may be better that the ones I used.
I have used float switched like these in my tanks as full indicators to prevent overfilling both water and diesel tanks which work OK as its in a procted environment.
