Which AQ130 is it?
ballabunch
19 Sep 2002
Isle of Man
Can anyone tell me how I can determine which of the AQ130s I have - A,B,C or D? I believe it is the C as that is what the previous owner told me, but I cannot verify this. Come to think of it... how can I check that it is a 130 and not a 115?
Also, there is no vacuum nor centrifugal advance on the distributors. I would have expected at least a centrifugal advance. Is this right? They are the Bosch 0-231-153-012 variety.
aquaholic
17 Jul 2004
London
Managed to find this if it helps
AQ130A: Used with the 100 and 250 series drive, ran 9.5:1 compression ratio and used Stromberg carbs. Rated at 130 hp.
AQ130B: Same as above but ran 8.4:1 compression ratio. Rated at 115 hp.
AQ130C: Used with the 250 and 270 series drive, ran 9.5:1 compression ratio and used Solex 44PA1 carbs. Rated at 130 hp.
AQ130D: Used with the 280 series drive, ran 9.0:1 compression ratio and used Solex 44PA2 carbs. Rated at 130 hp.
