RichardS
N/A
Welcome to your new happier life Richard !!
http://global.wago.com/en/products/product-catalog/terminal-blocks-connectors/overview/index.jsp
Specifically, for instrument wiring with easy spring push connections:
http://uk.farnell.com/wago/261-112-341-000/tb-wire-to-brd-12pos-14awg/dp/1283525
Many thanks Dom and Hydrozoan. Sorry about the delay but I'm now back home in the UK so catching up after the journey.
Those Wago things look like what I need and the 28 to 14 wire range looks right ....... but what do you actually have to do with these connectors? I can't see any screw heads. Does that mean that they are like the connectors from Halfords I use to join cables on car radios where you push down on the blades and they automatically cut through the insulation?
If these Wagos mean that I don't have to strip the ends off 30-odd tiny cables that would be a blessing. If I don't have to strip the cables again I will replace the choc block with the Wago as I do need to tidy-up all the wiring when I return to the boat in July as it's like a nest of snakes at the moment!
Richard
