where's this come from? Outboard ?
VicS
13 Jul 2002
Picked a tobacco tin up off the bench to hold small bits of what I was working on.
Inside the tin was this tiny fibre washer. Its obviously been left off something else ...... but what?
Mystery solved, I think
Years ago I was cleaning the Bing carb on an old outboard.
I thought I had lost a washer so a found one to replace it.
Then discovered that the old one had stayed down the hole, whereas previously it had always come out with the jet.
I must have left the potential replacement in the baccy tin
Proof, if proof were needed, that to really confuse someone who has an engine in bits you don't take a bit away, you put an extra bit into the pile.
A bit like lobbing a shackle pin onto the deck of a boat you are racing against. They spend so much time and energy looking for where it has come from that they lose sight of the race and fall behind.
