tidclacy
Can I get a large drop nose pin for my stem head. needs to be approx 210 mm long?Tried Google etc
If all else fails will try them
I am sure it will not be that expensive
John Davey has done work for me as have Fox`s
I gave up searching and made a pin from a long bolt with on ole drilled in the end, with a P clip to secure. Bolts available here:
http://www.a2stainless.co.uk/M8-x-1-25_B22WK7.aspx
It is worth making up a couple, case you lose one.
Can you see the one you want at Seascrew here
http://www.seascrew.com/browse.cfm?DROP-NOSE-PINS-316-STAINLESS--A4&l=0000000432
Good luck, George
Easy to buy off the shelf in any agricultural dealership, ask for three-point-linkage pin.
You silly boy
mine has a loop in the fixed end for a lanyard
In Stainless Steel?
< "Originally Posted by rustybarge
Easy to buy off the shelf in any agricultural dealership, ask for three-point-linkage pin.">
Stainless steel isn't maluable, so pins are never made out of stainless, as they could fracture under load.
Tractor linkage pins come in: long ones, short ones, thin ones, thick ones, with a hole in the end for snap locks. Cost about £10 - £15 or less.
