TactilePaul
thanks everyone, great answers as always, frayed corroded cables I shall look for, and will listen out for trouble , I cant imagine the brushes have had much wear, it gets cranked less than 500 times per year i recon..
Your starter was clearly still working, the relay had failed. Once the starter has actually failed on most modern engines you are under sail. Or if less competent under tow.My starter failed as I was sailing between Corfu and Albania with increasing wind. I did not relish the thought of sailing into Gouvia through the narrow channel. Luckily the engineer told me how to jump start the engine with a large screw driver.
TudorSailor
Not always true, there are several faults with the solenoid assembly which may be got around by shorting the solenoid contacts.Your starter was clearly still working, the relay had failed. Once the starter has actually failed on most modern engines you are under sail. Or if less competent under tow.
I suspect that, in this case, the term "relay" is being used interchangeably with "solenoid".Not always true, there are several faults with the solenoid assembly which may be got around by shorting the solenoid contacts.
Unfortunately we had the same problem when my wife started the engine once whilst I was casting off. A very quick tour along the river and back onto the pontoon eventually cost us about €500 after a week waiting for a replacement. We always check that the key goes back from the start position now...That's a painful reminder. My brand new Beta had 10 hrs on it, two keys on the ignition crossed over and jammed in the start position. Must have been running 15 mins before we noticed the smoke, and then we couldn't stop the beast! I only have 1 key on the switch now.
Do not underestimate the wear of the brushes. They are getting a small "mileage", but being almost pure carbon to deal with extreme currents and low voltage, they are very soft and wear much faster than on most "general purpose" motors.thanks everyone, great answers as always, frayed corroded cables I shall look for, and will listen out for trouble , I cant imagine the brushes have had much wear, it gets cranked less than 500 times per year i recon..
I went through that re-lubrication process a few days ago with an old 1976 Landy starter motor. However, I suspect that the OP's 15 year old starter motor is probably of the pre-engaged variety, although I might be wrong.Bendix springs rusting and failing - particularly the thin return spring
Bendix spiral getting clogged up and then bendix doesn't fly along properly -
I made a mistake when I decided to replace my Starter Motor.its maybe 15 + years old, a volvo md2030.. I am thinking that it may be the most likely thing that could leave me without engine??! I doubt it has done as much cranking as an average car would in one year, does this potentially extend its useful life?? and would anyone recommend a non volvo replacement? Opinions please, and tips on what else I should be looking at to ensure i don't call sea start this summer, aside from the common service/impeller/matrix issues.. thanks.
I had bought a 30 year old boat with a BMC inboard diesel engine.
Although it was working fine there was no service history about when it may have been changed or serviced (new brushes etc) so I had to assume it was the original 30 year old starter motor.
So I removed it (and I was glad I did) as it was obvious that at some time the bilges had been flooded. High enough to be over the dipstick hole and some oil must have come out as the inside of the starter motor was covered in yellow oil the colour that oil goes when mixed with seawater.
The mistake I made that I took advice from the local boatyard who said that they knew a firm which "reconditioned" starter motors.
Anyway, It was expensive, I then found that off the Internet I could have bought an ex-Lucas Reconditioned Starter Motor for about half the price of what I paid to have mine "reconditioned"
So although your Starter Motor may be a Bosche I would buy another.
There is a place in Manchester QX Components who have reconditioned starter motors on the shelf. The chances are that the starter motor for your engine being a Perkins 4-107 which was fitted to thousands of Massey Ferguson MF35 Tractors they may have on the shelf.
I know that I recently needed a starter for a 30 year old Benford Dumper which had a 3cyl Diesel and they reconditioned it quite cheaply.
I also notice that for old engines with a Lucas Dynamo you can get a new Alternator which looks like the original dynamo and obviously will work with the same fan belt.
Advertised in Classic Car magazines.
