daveg45
Following on from my mad dash across the Aegean post I have tried searching for info regarding anchoring. I carry a 20kg delta and 60m of 10mm chain and 30m of rope giving 90m of rode on a 42' light displacement yacht. In addition I carry an FX16 Fortress which although not the ideal size it came my way cheap and I thought it ok for a kedge. I had considered the idea of using the fortress in tandem with the delta if anchored in strong winds but having read this....
http://www.petersmith.net.nz/boat-anchors/tandem-anchoring.php
It seems my thoughts are misguided.
To be fair I have never felt the need to use a second anchor although the most I have anchored in is gusting 35ish knots. The only time a dragged was when I failed to put enough chain out.
So when the meltimi blows what do you do?
Why do manufacturers refer to boat size and not weight?
