VicS
It was after. We will see if I have continuing significant problems.
I have had a problem with the fuel hose coming unclipped and when I investigated this morning it was off, new connector needed as it seems to happen a little too regularly. The engine is greatly improved but may be in need of a tweek to mixture working under load rather than in a tank.
I did ask about replacing all the crankcase seals but was dissuaded by the mechanic who came highly recommended.
Remote tank? If so a bad connection, leading to air in-leakage, between tank and fuel pump could explain your symptoms. Worn O rings in fuel connector not unknown. Cheap after market connectors can be troublesome too I believe.
