stuhaynes
I've been told that the new red diesel only has a 'tank' life of about 6 months. Is this true? If it is, is there an additive that can extend it's life or is a tank clean going to be necessary every spring?
The issue with bio diesel is that it is actually biodegradeable and breaks down in as little as three weeks, and is hygroscopic to a large extent, which means it absorbs water, these are the main problems.
With normal road diesel we have a bio element averageing 5% bio content, this can be slightly higher or lower, but the normal diesel has a massive additives package as standard, so enhances the life of the bio element. Additives are available, but testing has shown them to have little affect on the life of bio.
The best advice is to run bio if you use the boat regularly, and if you store it for a period, or have a period of inactivity, then put a larger normal diesel content in prior to the inactivity.
