What wrong with my angle grinder?
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I have a Clarke angle grinder - used for half an hour a year for the past 4 years. Lives in the dry garage when notin use.
Last year worked fine. This year nothing.
I have checked:
Fuse
power through the switch
power to the brush-holders
brushes - lots left
no apparent damage or corrosion to windings
nothing seized.
Any ideas other than a trip to Machine Mart to buy a new one?
I use this for a flap wheel to whizz the small patches of rust off the keel before treatment. Will the flap wheel work effectively in an 18V power drill?
VicS
13 Jul 2002
I have checked:
Fuse
brushes - lots left
nothing seized.
Commutator?
Sans Bateau
19 Jan 2004
Using a multimeter, check to ensure you have continuity between the the brushes and the wires in the plug. Has the flex fractured?
Danbury
17 May 2013
Southsea
If it has one of those safety switches that needs to be slid somewhere before it works... is that sliding where it should ? No muck stopping it ?
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I had a similar problem with a detail sander that had had even less use than your grinder. I took it apart and could find nothing wrong. There was a capacitor(?) and I assumed that might have failed.
lw395
16 May 2007
I would check whether it actually makes a circuit.
Unplug, switch on, measure resistance across L & N pins of plug.
Should be quite low, less than 100 ohms.
Brushes could be stuck, armature could have failed.
Also field coil wiring could have failed.
Last power tool I saw with similar issues was mains flex gone intermittent where it goes into the tool.
Do of course check the socket is live with another appliance.....
lw395
16 May 2007
Start capacitor failed on my pillar drill after about 20 minutes use. Wouldn't expect one in a mini grinder, but I might be wrong.
Hard to test unless you have a capacitance meter, but I got a new cap on eBay for a few pounds.
VicS
13 Jul 2002
There may be a small capacitor for interference suppression .. Totally different to the start capicitor in induction motors.
I had the capacitor fail in an old electric drill. It kept blowing its fuse though. I could not figure out what was wrong so I put a bigger fuse in. Nothing to lose. One day there was a fecking big bang. Investigated and found the capacitor had blown itself to bits. Removed the remains, problem solved, still in use 30 years later at an age of about 60 years
Just get a new grinder. Cheap as chips. Move on.
Probably the best advice but its annoying when things go wrong and you cannot fix then a little or no cost.
jerrytug
N/A
31 May 2006
Lorient
Well Moody Sabre have you checked that 230v is actually getting to the brushes? Work your way back from there. You have to test it live with the power on, the grinder in a vice in case it starts because of an intermittent connection. And tape or clamp the switch 'on'.
I bet it's a loose connection, worth an hour checking it properly surely?
This is the *PRACTICAL* boat owners forum by the way, to the person who says buy a new one.
(I just pulled a new £200 Dyson out of the neighbours's bin, the fuse had gone, sad really)
lw395
16 May 2007
..... (I just pulled a new £200 Dyson out of the neighbours's bin, the fuse had gone, sad really)
I had a Dyson which blew a fuse, so I simply replaced the fuse.
It worked for an hour or so, then the fuse blew again.
So I replaced the fuse again, checked the motor was free to turn etc.
It worked for a minute or two, then had a serious attempt at catching fire. The armature seemed to have gone intermittently short.
However a new motor is not expensive for these things.
MoodySabre
24 Oct 2006
Jerry - I have checked continuity from the plug to the brushes. I can't check it live without taking the brushes out. Even if 230v isn't there then I can't fix it. Screwfix £15.99 here I come.
Heckler
24 Feb 2003
I suspect it could be the brushes sticking, check they move freely in the holder
Stu
Sans Bateau
19 Jan 2004
Woooooooooooow! MS! You've already got one cheapy which does work, I threw away a cheap angle grinder which failed after two or three uses and paid £35 for a Makita one. Buy cheap buy twice.
