Looks like it will need a 'proper' filter. I'd suggest a Racor clone. Why 'fitters' are still fitting stuff like that is beyond me.My engineer fitted it recently, and I want to know if I can change it for a filter with a water separator without changing the housing itself…
Me neither. Well not more than a teaspoonful.At the risk of being controversial, can I say that I've never seen any amount of water in the glass bowl of the filter/separator on my boats? Only 40-odd years to date, so still lots of opportunity to find some.
A glass bowl also allows you to look at the colour of the fuel. Is it clear or cloudy? If cloudy why?At the risk of being controversial, can I say that I've never seen any amount of water in the glass bowl of the filter/separator on my boats? Only 40-odd years to date, so still lots of opportunity to find some.
@Sandy Could you explain a bit more what you mean by this? I'm pretty ignorantLooks like it will need a 'proper' filter. I'd suggest a Racor clone. Why 'fitters' are still fitting stuff like that is beyond me.
If you want a drainable trap on the filter, look up the thread size and diameter for your existing Mahle KC20, then find either a can type filter with a bowl or a filter with a drain tap, with the same spin-on thread. eg 16x1.5 and filter diameter. Any large filter supplier should be able to help.
I had one of these:If you want a drainable trap on the filter, look up the thread size and diameter for your existing Mahle KC20, then find either a can type filter with a bowl or a filter with a drain tap, with the same spin-on thread. eg 16x1.5 and filter diameter. Any large filter supplier should be able to help.
KC 20 is here:If you want a drainable trap on the filter, look up the thread size and diameter for your existing Mahle KC20, then find either a can type filter with a bowl or a filter with a drain tap, with the same spin-on thread. eg 16x1.5 and filter diameter. Any large filter supplier should be able to help.
| Filter type | Screw-on Filter |
| Height [mm] | 80 |
| Connecting thread | M16x1,5 |
| Housing Diameter [mm] | 76 |
| Diameter 2 [mm] | 72,0 |
| Diameter 3 [mm] | 62,0 |
| Tightening Torque [Nm] | 14 |
| Part number of the recommended special tools | OCS1 |
OK there are a number of points in my comment:There does seem to be mixed views on whether or not a water separator is really necessary (not just online!).
It just feels to me that if I can have a filter including a water separator on there, for relatively low cost, I may as well.
@Sandy Could you explain a bit more what you mean by this? I'm pretty ignorant![]()
True, but I was suggesting that MattS get a 'proper filter' like a Racor clone. The CAV ones, in my experience, are hopeless as they filter from top down, not bottom up. The result is the brown gel produced by the fuel bug is hidden from view until you dismantle the unit and take the filter out. I do not want to inflict anything like the vomit induced few hours I experienced when changing my old CAV filter on the mooring many years ago - I dread to think what that would have been like in a seaway.With CAV-type filter heads, the fuel in the bowl has already been filtered, so visual inspection may not tell much.
