wakeup
+1 for gas BBQ, it is what we do on the bathing platform of our boat.
Shawn, can't comment on the wiring, but you will need something like a 10kVA gennie to run the a/c plus fridges plus plus....oh dear I can see this is going to get expensive as I am now looing at generators on the tinternet, so come on then what size do I need, I need to make sure if I go down this route its big enough to power air con if we do go to the med in a couple of years time. again air con is going to need to be retro fitted at a later date
regards a genny on my control panel there is a switch for a genny so does anyone know if my fairline will be wired up for a genny or will it just be a switch on the panel with nothing on the back of it
Your shorepower / genny select switch must be 'break before make', and normally it will be three position - SP - Off - Genny. I would expect it will be a 2 pole 3 position switch, so will have vacant terminals for the Off and Genny positions for each pole.
Whatever you decide make absolutely sure you cannot possibly have shorepower and genny power selected together, or you will destroy the genny, and possibly some of the wiring. Paralleling generators to shorepower is simply a non starter for small vessels with generators below say 50-100 kVA. I would be surprised if even JFM's Match II parallels to the shore supply system.
That sounds a bit strong to me. The theoretically correct approach to this is to work out what your aircon requirements are going to be, look at the startup electrical load, and from there you can size the generator. Alternatively, the easy way is to see what a med spec version of your boat has got installed ... and it'll probably be a Onan 7kw generator.
My Snazi, similar size to Shawn's Phantom has a Kohler 11 kVA, fitted as std. No a/c though, as she is a rare UK spec. The Phantom has a substantial greenhouse to cool, which your Targa doesn't need.
Jimmy, I need the gennie for the fridgeQuite - which is why I've only got a 4kw in mine, because that's all the aircon for my boat needs.
But ... hang on a minute, if you're dragging round 200kg of generator you don't need, and Shawn's got a grill that won't work at anchor ... is there a deal to be done??
An 11kw fridge? That is a _lot_ of stoli, Raf...
Hi Shaun - Speak to EBY they will advise you re generator size you can install etc etc - But speak with an Essex Accent and you won't go far wrong
....Shawn, I would think 6kva would be fine for a permanent install. That's around 20 ish amps. Years ago on my phantom 42 in the Med we had 5Kw and we had two small airco compressors not one, and switched them on sequentially not simultaneously to avoid start up spikes. These days you can have a soft start VFD (=variable frequency drive) added to the airco compressor motor for ~£100 to take out the start up spike so you don't even need to do the two compressor trick any more. I have VFD soft starts on all my big motors (airco, w'maker, stab hydraulics, etc) on my current boat because they're good things and cheap as chips these days.....
cheers john
yes we are thinking about the med but not for 2 years due to children we are looking at same marina as you and hurricane, we might even have a long weekend trip out there later this year to have a poke around but I know that will be lethal as it will speed up the move lol
