What tape on turnbuckles?
wonkywinch
30 Jul 2018
Hamble, UK
What tape do riggers use on turnbuckles to cover the split pin ends?
I replaced some with PVC electrical tape a month ago and it's already deteriorated in the winter sun.
Just tidying up the boat and wondered what the riggers use?
Small dia nylock nuts and bolts work really well.
At the moment I have split pins and have just replaced tape with shrink wrap (as used on electrical cables). Looks neat and dead easy to do.
I pin the turnbuckles with a pin attached to velcro. They last years, one set is over 10 years old when I replaced them. I recommend them, saves time, protects against snagging, easy to adjust rigging if that's required. Mine just stay in place all year after the mast is set up.
Blue Wave Smart Pins. The pins are made in different diameters.
Densyl tape if you must have tape. PVC electrical tape will only protect cables and terminals :ROFLMAO: 🤣 (Sorry😔)
Not sure about the ‘no tape’ answers as lots of professional riggers use tape.
I use white electrical tape. The trick is to make sure there’s drainage gaps. In other words just a few layers over the split pin. The other trick is NEVER pull the tape to snap it off. Let it relax and cut it and gently press it in place. That way it stays in place much longer.
Our tape lasts a year or two even in the tropical sun.
If only that were possible on ours. Otherwise perhaps you should have a word with all the professionals who use tape?
Just out of interest, why isn’t it possible on yours? My view is that at one of the most critical structural points on boat, what I really don’t want is tape covering up what’s going on there.
