Babylon
Elsewhere... small black ( not white ) cable ties work well.
Why not white? UV degradation or a poorer grade of plastic?
Its what is done on aircraft.
I don't mean to sound like a pedantic so and so, but do you mean "bob-stay" when you say "chain water stay"?
And I've seen, in the Harbour Office at Fowey, wire-locking on a mooring's shackle still intact and attached, but the shackle pin fully unwound, loose and dangling.![]()
Marsupial - not sure if you are replying to me. The point is that if the shackle is corroding it is protecting the wire, provided that is more noble. So why Monel? There are plenty of cheaper options that are more noble.
I'm certainly not saying that Monel doesn't work, just inquiring why a material nearly as expensive as gold is seen as necessary.
Someone suggested that I should 'mouse' my shackles. Where do I get this mousing wire from? Is it special, or can I use any old wire?
Did you ever reach a conclusion on wire composition? I still don't understand the need for a highly corrosion resistant, electropositive and expensive material like Monel in this application.... Is a 300 series stainless no good? or copper? or a low alloy steel? ...
Cable ties have been quite effective, but can get pinched and snap.
I was taught to mouse so as to secure against the 'undoing' direction of rotation, if you see what I mean, the idea being to prevent the slightest rotation rather than just retain the pin.
Good grief. How poor to you have to be to pinch cable ties? Even Scousers normally leave them when they take your hubcaps.
Lady C,
slightly disingenuous I think.
If you are/were a pro' military flyer, you should know that the Puma reservoir and Fowey mooring examples simply won't happen if the wire locking is properly done ( unless the reservoir blew apart, which is another matter ).
Nothing is that idiot-proof, if it's done incorrectly there will be problems.
I still suspect you might have had something to say if you'd been presented with a Puma, " Ok Sir we've sorted you out a good one; we've removed all the wire locking and fitted ty-wraps " !
Cable ties have their uses, tieing cables for instance, but will only ever be a poor second to proper wire-locking, to be used as a last resort, not by the lazy.
BTW I trained as a fitter on Hunters, Hawks & Harriers before going into general engineering training, and wire-locked a lot of cameras & things hanging under fast jets;I certainly don't feel anything in my eye...
S/Bleeder - "What's this, Chief? I snagged that myself last week..."
Chiefie - "Ground tested, found serviceable, sur..."
S/Bleeder - "Nope. Air tested, found unserviceable. You go fly it...."
