Portofino
I was going to make the same question.
As I recall from a previous thread, PF mentioned that his typical fuel burn is 180 l/h at a cruise speed of 27/28 kts.
So, he should burn around 2500 litres to make 377Nm, and that's without considering any reserve.
Sounds like a helluva tankage, for a boat like his...![]()
Each boat approx 21 was built to order .Mines hull no 12 .
STD 800 x 2 tanks straddling the centre geny behind the central ( relative to the boat vol ) engines .Tanks are behind the gearboxes trapezoid shaped into the V .Behind those is a bulk head of the twin + en-suite stern cabin - where most boats have an ER .
No owners fwd shower room , dinette enlarged , bigger day heads in lieu of seperate shower with a connecting door to the fwd owners cabin .AND and extra long range tank on the stb side of another 800 , so 3x800 ,
There are two fuel fillers on the stb side deck and one on the port deck .
All three tanks are interchangeable by various cocks / valve s in a suede rubricks cube esk way
When the LR tank is full , despite the slight internal rearranging less kg on the stb side due to loss of shower room ,the boat lists to stb it’s quite visible and the slime tide mark @ haul out looks odd to say the least .
This summer after checking it for the dreaded bug I opened up the various cocks connecting the three tanks up and emptied the reserve .
I think I’ve been running round with a spare 800 L for the past 3 years totally oblivious.
There’s no guage or sight glass so you can’t tell what’s in it .
I did it by tapping all three tanks the main two are guaged and sight glassed so I worked out by the tap sound the reserve must have been full . It was ,
Funnily enough I was on the boat last WE with about a 1/4 or less in the two main tanks and it felt it now lists ever so slightly to the port side ,but only a v tiny list ,
I always dose with diesel anti bug even in the summer and a big dose at the last fill up before the winter .
Well the 3 + year old 7/800 L reserve, like a fine wine seemed ok when the engines drank it .Its empty now as it’s mounted ( straight rectangular shape ) higher then the inlet on the main on the stb side .So with the relivant cocks open you can empty it .
Not sure why the original owner specced the LR tank ,but he’s a serial Itama owner with a hotel on Capri and uses the boat for Naples taxi and day trips .Fiammetta 3 is a XL 51 made in the same yard by the same guys with the old moulds in Roma .
