l'escargot
Can anyone identify this light for me please?
On a Yamaha diesel inboard with outdrives.
There is no sensor in the coolant header tank and that is up to level as is the coolant. I would look in the manual if I had one, but I don't - that's why I asked on here.Agree with ripster, looks like a coolant level warning. I know its not a bloke thing but dare I suggest you look in the manual?![]()
A Yam manual I just looked at online says that a warning sign just like that is the coolant level alarm. Why would there be a sensor in the header tank anyway? More likely the sensor is below the level of the header tank IMHO but I may be wrongThere is no sensor in the coolant header tank and that is up to level as is the coolant. I would look in the manual if I had one, but I don't - that's why I asked on here.![]()
its almost certainly a level indicator but could be water or oil could be worth checking drive oil reservoir level as I know the mercruiser system links the drive oil into the same light as the engine oil
Do you know the engine type no?Ripster, who you agreed with, suggested it was "...coolant header tank low". Surely for it to light an indicator, it would need a sensor? But I've checked, the header tank is up to level - I've removed the pressure cap and checked and the expansion tank has coolant in it too.
I think Mike's agreeing that there's a sensor, he's just suggesting it might not be in the header tank itself, it might be below it (on the basis that the warning light only comes on when the level is well below the normal level, ie perhaps below the bottom of the header tank).
What specific model of yamaha engine is it? Is the helm panel OE or aftermarket?
I think that refers to the outdrive not the engineI've got conflicting paperwork which says DE-DHD and says both 180 and 240 HP.
That wouldn't surprise me, as I said the paperwork is conflicting and has been copied from other documents. I will get back tomorrow and have a look at the engine plates.I think that refers to the outdrive not the engine
This is the full set of lights:
Of just the red lights, I would guess the middle left would be oil pressure and bottom left would be oil level; middle right water pressure and bottom right coolant level. With Top left alternator and top right coolant temperature).
I did take quite a bit of weed out of the water filter and the warning light now goes out when the revs go up so it looks like it might be indicative of a partial water blockage, the warning is intermittent at tick over. Checking the water pump impeller might be the next step.
I would still appreciate confirmation from anyone with actual knowledge of this set up that I am guessing the warning lights correctly though.
