What is the worst sailing or marine invention ever?
CalicoJack
5 Jan 2004
Chatham, Kent
The Seafarer RDF. For those of you lucky enough never to have come across one, it was an instrument of torture used by my father. He would give the machine to me and you began by inserting a stethoscope like device into your ears. Then having turned it on you were supposed to set the frequency and aim it, it had a large compass on the top of it. You got an earful of static and then a morse letter, I think when you were pointing it at the distant station. You then read the bearing off the top. Repeat three time for different stations and draw a cocked hat, about the size of Luxembourg on your chart. Sorry if this is wrong, only excessive amounts of beer the night before and one of these horrors have made me seasick. In fact just the thought is making me feel a bit queasy.
Greenheart
29 Dec 2010
The Seafarer RDF...In fact just the thought is making me feel a bit queasy.
Your description does sound dreadful. Glad I never encountered it. Doubtless it was regarded as a boon when there was no better way to gauge your whereabouts, but, pretty grim.
Maybe we ought to be more appreciative of today's easy answers than is sometimes expressed here.
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
The procedure was that, having tuned into a beacon signal and made sure it was the correct one - difficult in itself if, like most of us, you aren't proficient in Morse Code - you then rotated the instrument until the signal disappeared. That gave you a bearing on the beacon.
Most of the time the thing was not much use - its range was such that in general, in clear weather you could get compass bearings if the thing would pick up a signal. It did once come into its own on a trip where fog came down off the East Coast of Scotland; bearings on a aeronautical beacon have us distance along track.
The real problem was that it wasn't all that accurate - the nulls were at least 10-20 degrees wide, so the best accuracy was 5-10 degrees. The other problem was that radio beacons were few and far between - AFAIR, there were only 2-3 available between Dunbar and Fraserburgh, and they were aeronautical beacons, at least one of which was off the edge of the charts! You couldn't usually get enough for a fix, so you had to use them as an additional bearing in conjunction with other navigational techniques. Useful in fog; pretty much useless otherwise!
There was another problem - at the wavelengths they operated on, a signal passing obliquely across a coastline could be refracted so the bearing you got wasn't actually pointing towards the beacon! They were really only useful if the signal was pretty much at right-angles to the coast.
Alan ashore
16 Oct 2012
Teddington
+1 to the telescopic boat hook. I'd also add the completely useless telescopic deck brush to that.
I have found the telescopic deck brush to be absolutely brilliant for hull scrubbing in the water. (I've always had the Vikan ones which extend to 2.8m or thereabouts - used to be readily available in chandlers, but harder to get hold of now I fear. A quick online search finds various brushes which seem to extend up to the length of a broom handle, which I too would find useless.....)
BrianH
31 Jan 2008
Switzerland
www.brianhenry.byethost18.com
I beg to differ; although mine was a home-made one with a domestic transistor radio - with the long-wave extended to cover the RDF beacon frequencies - fitted into a wooden pelorus mounted on the aft bulkhead. The pelorus was marked in degrees from the yacht's bow and the null noted and applied to the current compass heading, thus giving the beacon's bearing.
Returning from Holland to NE Yorkshire a lifetime or two ago I was overtaken by a full gale six hours out of Den Helder and lay a-hull for 17 hours, after which my trusty RDF unit and three beacons put me in a surprisingly small cocked hat slap in the middle of the North Sea with my destination, Whitby, 100nm directly west of my position. I had drifted 42nm from my previous DR position before lowering all sail.
The worst yachting development is absolutely teak decks screwed down to the grp base... Time to go to replace another set of teak plugs and sink the screws to accept them.
TQA
20 Feb 2005
Carribbean currently Grenada
sailingonelephantschild.blogspot.com
Or it could be a lot noisier without GPS. With all the rescues going on, boats aground right and left, newbies lost as soon as they are out of sight of the dock, it would be a madhouse.
Nah they stay in port. It is the ones with GPS and plotters and who believe in them who hit the bricks out in the Carib. Fings ain't where the moving finger says they are.
Puggy
7 May 2007
Hampshire, UK
Honda 2.3hp outboards. Hard to start with a wrist breaking kick back, temperamental, leak oil all the time, very noisy, and constructed with a selection of mild steel bolts. Oh, and bloody expensive for what they are: a rattly cement mixer engine.
